默认的bootcommand就是执行的这个操作啊,先从SD卡启动,如果没有SD卡,从NAND启动:
"mmc dev $[mmcdev]; if mmc rescan; then "
"echo SD/MMC found on device $[mmcdev];"
"if run loadbootenv; then "
"echo Loaded environment from $[bootenv];"
"run importbootenv;"
"fi;"
"if test -n $uenvcmd; then "
"echo Running uenvcmd ...;"
"run uenvcmd;"
"fi;"
"if run loaduimagefat; then "
"run mmcboot;"
"elif run loaduimage; then "
"run mmcboot;"
"else "
"echo Could not find $[bootfile] ;"
"fi;"
"else "
"run nandboot;"
"fi;"
"fi;"
"run uenvcmd;"
"fi;"
"run mmcboot;"
"run mmcboot;"
"else "
"fi;"
"else "
"run nandboot;"
"fi;"
