AVR技术论坛
laoduwu
12年用户 27经验值
擅长:模拟技术 嵌入式技术
[AVR问答]
ATMEGA162两串口通信乱码
因为需要两串口,初次接触162,才发现不是想象的那样顺。让串口接收的数据立即让另一个发出去,protues仿真结果只有80和00,想请高手指点迷津,下面是程序:
#include"mega162.h"             //7.3728MHZ-38.4K;
#define uchar unsigned char
#define uint unsigned int
uint uartdat0,uartdat1;       //uartdat:串口接收,pardat并口接收 len=0,
void USART0_Transmit(uint sdat0);
void USART1_Transmit(uint sdat1);
interrupt[USART0_RXC]void usart0_rx_isr(void)  //串口0接收
      uartdat0=UDR0;
      PORTA=uartdat0;USART1_Transmit(uartdat0);
void USART0_Transmit(uint sdat0)    //串口0发出
   {  while(!(UCSR0A&(1<<5)));
      UDR0=sdat0;
interrupt[USART1_RXC]void usart1_rx_isr(void)  //串口1接收
      uartdat1=UDR1;
      PORTC=uartdat1;  USART0_Transmit(uartdat1);
void USART1_Transmit(uint sdat1)    //串口1发出
   {  while(!(UCSR1A&(1<<5)));
      UDR1=sdat1;
  void main(void)
     DDRA=0xff;
     PORTA=0xff;
     DDRB=0x08;
     PORTB=0;
     DDRC=0xff;
     PORTC=0xff;
     DDRD=0x02;
     PORTD=0;
    UCSR0B = 0x00;
    UCSR0A=0x00;
    UCSR0B = 0x98;
  //  UCSRB.7=1;UCSRB.4=1;UCSRB.3=1;//允许接收中断、发送和接收
    UBRR0L=11;         //(fosc/16/(baud+1))%256;  11.0592MHZ-38.4k-17;11.0592-4800-143;
    UBRR0H=0;          //(fosc/16/(baud+1))/256;   7.3728MHZ-38.4k-11;
    UCSR0C=0x86;       //8位数据+1位STOP位-86;寄校验-B6
    UCSR1B = 0x00;
    UCSR1A=0x00;
    UCSR1B = 0x98;
    UBRR1L=11;         //(fosc/16/(baud+1))%256;  11.0592MHZ-38.4k-17;11.0592-4800-143;
    UBRR1H=0;          //(fosc/16/(baud+1))/256;   7.3728MHZ-38.4k-11;
    UCSR1C=0x86;       //8位数据+1位STOP位-86;
    #asm("sei")         //SREG   = 0x80; //开总中断
    while(1)
     #asm("nop");
laoduwu
2017-9-1 22:11:37
哦,解决了,谢谢
