移动通信
关键词: LED驱动器 , LNK406EG , PAR30 , Powerint
Powerint公司的13.5W隔离的可调光的PFC LED驱动器采用LinkSwitchTM-PH系列的LNK406EG器件,输入电压185VAC到265VAC,输出36V/425mA,可用于PAR30 / PAR38反射灯.本文介绍了LinkSwitch-PH系列LED驱动器主要特性,框图,7W和14W LED驱动器电路图以及用于PAR30 / PAR38的13.5W LED驱动器参考设计DER314主要特性和指标,电路图和材料清单,变压器电路图和PCB布局图.
2012-2-7 13:00:19 上传
The LinkSwitch-PH dramatically simplifies implementation of LED drivers requiring long lifetime, high efficiency, PF >0.9, and TRIAC dimming capability (LNK403-409). The single-stage combined power factor and constant-current controller eliminates a switching stage and the electrolytic bulk capacitor. The advanced primary-side control used by the LinkSwitch-PH device provides accurate constant current control while eliminating the need for an optocoupler and current sensing circuits.
LinkSwitch-PH incorporates a 725 V power FET, a continuous-mode PWM controller, a high voltage switched current source for self biasing, frequency jittering, protection circuitry including cycle-by-cycle current limit and hysteretic thermal shutdown.
LinkSwitch-PH LED驱动器主要特性:
Product Highlights
Dramatically Simplifies Off-line LED Drivers
• Single-stage combination of power factor correction and accurate constant-current (CC) output
• Enables very long lifetime designs (no electrolytic capacitors)
• Eliminates optocoupler and all secondary current control circuitry
• Eliminates control loop compensation circuitry
• Simple primary-side PWM dimming interface
• Universal input voltage range
• LNK403-409 optimized for flicker-free TRIAC dimming
EcoSmart™ – Energy Efficient
• Single-stage PFC combined with output CC control
• Greatly increases efficiency, >90% achievable
• Reduces component count
• No current sense resistors
• Low standby power remote ON/OFF feature (<50 mW at 230 VAC)
Accurate and Consistent Performance
• Compensates for transformer inductance variations
• Compensates for line input voltage variation
• Frequency jittering greatly reduces EMI filter size and cost
Advanced Protection and Safety Features
• Auto-restart for short-circuit protection
• Open circuit fault detection mode
• Automatic thermal shutdown restart with hysteresis
• Meets high voltage creepage requirement between DRAIN and all other signal pins both on PCB and at package
Green Package
• Halogen free and ROHS compliant package
LinkSwitch-PH应用:
• Off-line LED driver
下载附件 (19.04 KB)
下载附件 (19.67 KB)
下载附件 (47.58 KB)
下载附件 (64.99 KB)
下载附件 (37.3 KB)
下载附件 (24.32 KB)
下载附件 (109.13 KB)
下载附件 (6.32 KB)
下载附件 (31.83 KB)
下载附件 (73.72 KB)
2012-2-7 13:05:07 上传
下载次数: 0
2012-2-7 13:07:31 上传
下载次数: 0全部0条评论
