移动通信
关键词: LED驱动 , MAX16814 , Maxim
Maxim 公司的MAX16814是集成了高压DC/DC控制器的四路高亮LED(HBLED)驱动器,输入电压4.75V-40V,能经受住汽车负载突变,可调输出电流从20mA到150mA,以驱动一到四串LED,开关频率200kHz到2MHz,自适应输出电压以最小化功耗,关断电流小于40uA,主要用在汽车显示屏LED背光,汽车RCL,DRL,前灯和雾灯,建筑物,工业和环境灯照明.本文介绍了MAX16814主要特性,功能框图,典型应用电路以及MAX16814 评估板主要特性,电路图,材料清单和PCB布局图.
2012-4-20 12:41:52 上传
The MAX16814 high-efficiency, high-brightness LED (HB LED) driver provides up to four integrated LED current-sink channels. An integrated current-mode switching DC-DC controller drives a DC-DC converter that pro-vides the necessary voltage to multiple strings of HB LEDs. The MAX16814 accepts a wide 4.75V to 40V input voltage range and withstands direct automotive load-dump events. The wide input range allows powering HB LEDs for small to medium-sized LCD displays in automotive and general lighting applications.
An internal current-mode switching DC-DC controller supports the boost, coupled-inductor boost-buck, or SEPIC topologies and operates in an adjustable fre-quency range between 200kHz and 2MHz. It can also be used for single-inductor boost-buck topology in conjunc-tion with the MAX15054 and an additional MOSFET. The current-mode control with programmable slope com-pensation provides fast response and simplifies loop compensation. The MAX16814 also features an adaptive output-voltage control scheme that minimizes the power dissipation in the LED current-sink paths.
The MAX16814 consists of four identical linear current source channels to drive four strings of HB LEDs. The channel current is adjustable from 20mA to 150mA with an accuracy of ±3% using an external resistor. The external resistor sets all 4-channel currents to the same value. The device allows connecting multiple channels in parallel to achieve higher current per LED string. The MAX16814 also features pulsed dimming control, on all four channels through a logic input (DIM). In addition,the MAX16814A_ _ and MAX16814U_ _ include a unique feature that allows a very short minimum pulse width as low as 1μs.
The MAX16814 includes an output overvoltage, open- LED detection and protection, programmable shorted LED detection and protection, and overtemperature pro-tection. The device operates over the -40NC to +125NC automotive temperature range. The MAX16814 is avail-able in 6.5mm x 4.4mm, 20-pin TSSOP and 4mm x 4mm, 20-pin TQFN packages.
MAX16814主要特性:
4-Channel Linear LED Current Sinks with Internal MOSFETs Full-Scale LED Current Adjustable from 20mA to 150mA Drives One to Four LED Strings Boost, SEPIC, or Coupled-Inductor Boost-Buck Current-Mode DC-DC Controller 200kHz to 2MHz Programmable Switching Frequency External Switching Frequency Synchronization
Adaptive Output-Voltage Optimization to Minimize Power Dissipation
4.75V to 40V Operating Input Voltage Range
Less than 40μA Shutdown Current
5000:1 PWM Dimming at 200Hz (MAX16814A _ _ and MAX16814U_ _ Only)
Open-Drain Fault Indicator Output
Open-LED and LED Short Detection and Protection
Overtemperature Protection
Thermally Enhanced, 20-Pin TQFN and TSSOP Packages
MAX16814应用:
Automotive Displays LED Backlights
Automotive RCL, DRL, Front Position, and Fog Lights
LCD TV and Desktop Display LED Backlights
Architectural, Industrial, and Ambient Lighting
下载附件 (25.26 KB)
下载附件 (18.64 KB)
下载附件 (18.58 KB)
下载附件 (28.23 KB)
下载附件 (37.62 KB)
下载附件 (37.46 KB)
下载附件 (40.98 KB)
下载附件 (39.51 KB)
2012-4-20 12:38:07 上传
下载次数: 0
2012-4-20 12:38:41 上传
下载次数: 0全部0条评论
