应用案例
TI公司的LMR33630是SIMPLE SWITCHER®稳压器,提供最好效率容易使用的降压DC/DC转换器,输入电压高达36V,负载电流高达3A,能在解决方案非常小尺寸提供轻负载高效率(峰效率大于95%)和输出高精度,输入电压3.8V-36V,输出电压1V-24V,集成了75 mΩ/50 mΩRDS-ON功率MOSFET,峰值电流模式控制,开关频率400 kHz,1.4 MHz和2.1 MHz,主要用在马达驱动系统如无人机,AC逆变器,VF驱动和伺服系统,工厂和建筑物自动化系统如PLC CPU,HVAC控制,电梯控制以及通用宽VIN电源.本文介绍了LMR33630主要特性,功能框图和应用电路,以及评估模块LMR33630 EVM主要特性,电路图,材料清单和PCB设计图.
The LMR33630 SIMPLE SWITCHER® regulator is aneasy-to-use, synchronous, step-down DC/DCconverter that delivers best-in-class efficiency forrugged industrial applications. The LMR33630 iscapable of driving up to 3 A of load current from aninput of up to 36 V. The LMR33630 provides highlight load efficiency and output accuracy in a verysmall solution size. Features such as a power-goodflag and precision enable provide both flexible andeasy-to-use solutions for a wide range of applications.
The LMR33630 automatically folds back frequency atlight load to improve efficiency. Integration eliminatesmost external components and provides a pinoutdesigned for simple PCB layout. Protection featuresinclude thermal shutdown, input undervoltage lockout,cycle-by-cycle current limit, and hiccup short-circuitprotection. The LMR33630 is available in an 8-pinHSOIC package and in a 12-pin 3 mm × 2 mm VQFNpackage with wettable flanks. This device is alsoavailable in an AEC-Q100-qualified version.Thisdevice is also availabe in an AEC-Q100 qualifiedversion.
LMR33630主要特性:
1• Configured for Rugged Industrial Applications
– Input Voltage Range: 3.8 V to 36 V
– Output Voltage Range: 1 V to 24 V
– Output Current: 3 A
– 75 mΩ/50 mΩ RDS-ON Power MOSFETs
– Peak-Current-Mode Control
– Short Minimum On-Time of 68 ns
– Frequency: 400 kHz, 1.4 MHz, 2.1 MHz
– Junction Temperature Range –40℃ to+125℃
– Low EMI and Low Switching Noise
– Integrated Compensation Network
• High Efficiency Solution
– Peak Efficiency > 95%
– Low Shutdown Quiescent Current of 5 μA
– Low Operating Quiescent Current of 25 μA
• Flexible System Interface
– Power-Good Flag and Precision Enable
• Create a Custom Design Using the LMR33630with the WEBENCH® Power Designer
LMR33630应用:
• Motor Drive Systems: Drones, AC Inverters,VF Drives, Servos
• Factory and Building Automation Systems:PLC CPU, HVAC Control, Elevator Control
• General Purpose Wide VIN Power Supplies
