General Description
The TQM7M6025 PA Module integrates two high efficiency BiHEMT power amplifiers, input band select switch, directional coupler and Vreg circuitry into a compact 4.0 mm x 3.0 mm package. TriQuint’s CuFlip® assembly technology and BiHEMT GaAs process provides a compact, low cost solution optimized for the Qualcomm WTR2605 transceiver with state-of-the-art HPM PAE. The TQM7M6025 is a power amplifier module for bands 2, 25 & 5, 26 for use with WCDMA and BC0 and BC1 for CDMA modulations. As a result of the combination of high performance, low cost and small size it is well suited for both mobile handset and data card applications.
Applications
BC0 / BC1 CDMA / EVDO Handsets / Data cards Bands 2 & 5 WCDMA Handsets / Data Cards HSDPA / HSUPA / HSPA+
Product Features
Integrated high efficiency dual-band two gain state power amplifier, VREG circuitry, input band select switch and directional coupler Multi-Band coverage o High Band 2, 25, BC1 (1850 – 1915 MHz) o Low Band 5, 26, BC0 (814 – 849 MHz) Small Size = 4.0 mm x 3.0 mm Low Quiescent Current in LPM High Max Power PAE No External Voltage Regulation Required APT (Average Power Tracking) Capable
