——来自迪文开发者论坛
本期为大家推送一个很有创意的迪文开发者论坛获奖开源案例——浏览器网页与T5L迪文屏串口深度扩展(Node-RED技术)。工程师使用T5L智能屏,通过Node-RED技术,只需要一个串口,就可以接入互联网,实现迪文屏与浏览器网页的数据交互。该方案实现了智能屏与网页端的数据收发、图表交互、基本信息显示等功能。
Node-RED网页端运行效果展示 (1)使用Node-RED技术,以浏览器作为交互入口,使浏览器与屏幕通过串口交互,实现相应功能展示。
数据收发Tab页面
图标交互Tab页面
基本信息Tab页面效果
(2)Node-RED网页端主要参考代码如下:
"id": "fbb314a16ea00889",
"type": "serial in",
"z": "09e0777eaff7fdea",
"g": "c1661722c7db00f9",
"name": "串口接受数据",
"serial": "83fb45b5f4b51d61",
"x": 390,
"y": 140,
"wires": [
"685a2fb2c2dc8fba"
"id": "1ba3c6e812e03e27",
"type": "serial out",
"name": "串口发送",
"x": 860,
"y": 260,
"wires": []
"id": "5fb7f1d3d7425133",
"type": "status",
"name": "监听串口状态",
"scope": [
"fbb314a16ea00889"
"x": 390,
"y": 200,
"wires": [
"3f18d1fdea398d35"
"id": "3f18d1fdea398d35",
"type": "function",
"name": "提取串口状态",
"func": "let sta = msg.status.text;\nlet color = 'red';\nif (sta.indexOf('not-connected') >= 0) \n sta = '未连接';\nelse if (sta.indexOf('connected') >= 0)\n{\n sta = '连接成功';\n color = 'green';\n}else\n sta = '出现错误';\nmsg['payload'] = sta;\nmsg['color'] = color;\n\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 620,
"y": 200,
"wires": [
"2ec78ff0b0b9a56f"
"id": "2ec78ff0b0b9a56f",
"type": "ui_template",
"group": "4e4db779a7b91019",
"name": "显示串口状态",
"order": 1,
"width": 0,
"height": 0,
"format": "
\n 串口状态:
DGUS界面设计
C51工程设计
方案采用T5L智能屏串口2与Node-RED网页通信,部分参考代码如下:
#include "sys.h"
#include "uart2.h"
#include
#include
u8 buff[200];
void main(void)
u16num;
u16val;
u16old;
u8i;
sys_init();
uart2_init(115200);
old= 0;
while(1)
if(is_recv_complete)
uart2_buf[recv_len++]= 0;
if(strstr((char*)uart2_buf,"cmd"))
num= uart2_buf[3]-'0';
if(num<3)
for(i=0;i<3;i++)
val= (num==i);
sys_write_vp(0x2300+i,(u8*)&val, 1);
}elseif(num<5)
val= (num==3);
sys_write_vp(0x2200,(u8*)&val, 1);
}else
sys_write_vp(0x2000,uart2_buf, recv_len/2+2);
recv_len= 0;
is_recv_complete= 0;
sys_read_vp(0x1000,(u8*)&val, 1);
if(val==1)
sys_read_vp(0x2100,buff, 50);
for(i=0;i<100;i++)
if(buff==0xff)
buff= 0x00;
buff[i+1]= 0x00;
break;
u2_send_bytes(buff,strlen(buff));
val= 0;
sys_write_vp(0x1000,(u8*)&val, 1);
sys_read_vp(0x2400,(u8*)&val, 1);
if(val!=old)
sprintf(buff,"%d", val);
old= val;
