一、准备
本篇文章主要介绍使用RT-Thread Studio 和瑞萨 CPK-RA2L1评估板,使用攀藤PMS1003 作为pm2.5 ,pm10等粉尘颗粒信息采集传感器
二、模块信息
通过官网对PMS1003的介绍,可通过uart通信采集数据,以及该传感器的各项技术性能指标
三、新建工程
根据上面了解的模块信息,使用UART0 作为通信接口,注意波特率为:9600 ,数据包长32字节
在RT-Thread Settings种配置好 UART驱动程序,和打开硬件模块的UART0 开关
在 RA Smart Configurator 种添加UART0,配置好引脚和波特率
四、代码实现
Change Logs:
Date Author Notes
2021-10-10 Sherman first version
#include
#include "hal_data.h"
#include
#define LED1_PIN "P502" / Onboard LED pins /
#define DBG_ENABLE
#define DBG_SECTION_NAME "pms_series"
#define DBG_LEVEL DBG_LOG
#define DBG_COLOR
#include
#include
#define PMS_SERIES_UART "uart0"
#define DBG_ENABLE
struct rx_msg
rt_device_t dev;
rt_size_t size;
#ifdef PMS_SERIES_SAMPLE_USING_DMA
struct rt_messagequeue pms_mq;
#else
struct rt_semaphore pms_sem;
#endif
void pms_series_debug(pms_device_t dev)
LOG_D("begin *");
LOG_D("PM1_0_CF1 = %5dtPM2_5_CF1 = %5dtPM10_0_CF1 = %5d",dev->PM1_0_CF1,dev->PM2_5_CF1,dev->PM10_0_CF1);
LOG_D("PM1_0_amb = %5dtPM2_5_amb = %5dtPM10_0_amb = %5d",dev->PM1_0_amb,dev->PM2_5_amb,dev->PM10_0_amb);
LOG_D("air_0_3um = %5dtair_0_5um = %5dtair_1_0um = %5d",dev->air_0_3um,dev->air_0_5um,dev->air_1_0um);
LOG_D("air_2_5um = %5dt",dev->air_2_5um);
LOG_D("version = %5d errorCode = %5d",dev->version,dev->errorCode);
LOG_D(" over *****");
static void serial_thread_entry(void *parameter)
#ifndef PMS_SERIES_SAMPLE_USING_DMA
rt_err_t result;
char ch;
pms_device_t dev = parameter;
while (1)
while (rt_device_read(dev->serial, 0, &ch, 1) == 0)
rt_sem_control(&pms_sem, RT_IPC_CMD_RESET, RT_NULL);
rt_sem_take(&pms_sem, RT_WAITING_FOREVER);
result = pms_get_byte(dev,ch);
if (result == RT_EOK)
pms_series_debug(dev);
#endif
struct rx_msg msg;
rt_err_t result;
rt_uint32_t rx_length;
static rt_uint8_t rx_buffer[RT_SERIAL_RB_BUFSZ + 1];
while (1)
rt_memset(&msg, 0, sizeof(msg));
result = rt_mq_recv(&pms_mq, &msg, sizeof(msg), RT_WAITING_FOREVER);
rx_length = rt_device_read(msg.dev, 0, rx_buffer, msg.size);
rx_buffer[rx_length] = '�';
result = frame_check(dev,rx_buffer,rx_length);
LOG_D("rx buff success");
else
LOG_E("rx buff error");
#endif
static rt_err_t uart_input(rt_device_t dev, rt_size_t size)
RT_ASSERT(dev);
if (size > 0)
rt_sem_release(&pms_sem);
return RT_EOK;
#endif
rt_err_t result;
struct rx_msg msg;
msg.dev = dev;
msg.size = size;
result = rt_mq_send(&pms_mq, &msg, sizeof(msg));
if ( result == -RT_EFULL)
rt_kprintf("message queue full!n");
return result;
#endif
//int pms_sample(int argc, char *argv[])
int pms_sample()
static pms_device_t dev = NULL;
rt_err_t ret = RT_EOK;
dev = pms_init(PMS_SERIES_UART);
rt_sem_init(&pms_sem, "pms_sem", 0, RT_IPC_FLAG_FIFO);
rt_device_open(dev->serial, RT_DEVICE_FLAG_INT_RX);
rt_device_set_rx_indicate(dev->serial, uart_input);
#endif
static char msg_pool[256];
rt_err_t result;
result = rt_mq_init(&pms_mq, "pms_mq",
msg_pool,
sizeof(struct rx_msg),
sizeof(msg_pool),
RT_IPC_FLAG_FIFO);
if (result != RT_EOK)
LOG_E("init message queue failed.n");
result = rt_device_open(dev->serial, RT_DEVICE_FLAG_DMA_RX);
LOG_E("open device failed.n");
result = rt_device_set_rx_indicate(dev->serial, uart_input);
LOG_E("set rx indicate failed.n");
#endif
rt_thread_t thread = rt_thread_create("serial", serial_thread_entry, dev, 1024, 3, 10);
if (thread != RT_NULL)
rt_thread_startup(thread);
else
ret = RT_ERROR;
return ret;
INIT_APP_EXPORT(pms_sample);
//MSH_CMD_EXPORT(pms_sample, pms_series drive sample);
void hal_entry(void)
rt_kprintf("nHello RT-Thread!n");
rt_uint32_t led1_pin = rt_pin_get(LED1_PIN);
while (1)
rt_pin_write(led1_pin, PIN_HIGH);
rt_thread_mdelay(500);
rt_pin_write(led1_pin, PIN_LOW);
五、 烧录验证
