这是之前写平衡小车时自己用TIM的PWM输出模式写了一个步进电机的Stepper库函数。
1
调用顺序
1.1
init函数
1.2
begin函数
1.3
setSpeed函数
2
Stepper类结构
3
TIM结构框图
Stm32手册中的结构框图很重要,只要理解了外设的运行逻辑,按照逻辑一步一步给寄存器设值就可以让外设按我们的要求运行。
#ifndef __STEPPER_H
#define __STEPPER_H
#include "peripheral.h"
#include "math.h"
#ifdef __cplusplus
extern "C"
#endif
enum DIRCTION
POS,
INV
class Stepper
private:
/* data */
uint16_t TIMx_prescaler = 0;
uint32_t TIMx_freq = 0;
TIM_TypeDef *TIMx;
uint32_t Channel;
float speed;
public:
Stepper(TIM_TypeDef *TIMx, uint32_t Channel);
~Stepper();
void init();
void gpio_init();
void begin();
void stop();
void setDirection(DIRCTION dir);
void setFreq(uint16_t freq);
void setSpeed(float speed);
float getSpeed();
extern Stepper Stepper_left;
extern Stepper Stepper_right;
#ifdef __cplusplus
#endif
#endif
#include "Stepper.h"
Stepper Stepper_left(TIM1, LL_TIM_CHANNEL_CH1);
Stepper Stepper_right(TIM2, LL_TIM_CHANNEL_CH2);
Stepper::Stepper(TIM_TypeDef *TIMx, uint32_t Channel)
this- >TIMx = TIMx;
this- >Channel = Channel;
Stepper::~Stepper()
void Stepper::init()
//开定时器外设时钟
if (TIMx == TIM1)
LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_TIM1);
//设置预分频器
LL_TIM_SetPrescaler(TIMx, 90);
TIMx_freq = 90000000;
TIMx_prescaler = 90;
if (TIMx == TIM2)
LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_TIM2);
//设置预分频器
LL_TIM_SetPrescaler(TIMx, 45);
TIMx_freq = 45000000;
TIMx_prescaler = 45;
//定时器选择时钟源
LL_TIM_SetClockSource(TIMx, LL_TIM_CLOCKSOURCE_INTERNAL);
//设置自动重载寄存器
LL_TIM_SetAutoReload(TIMx, 2000 - 1);
//设置计数方向
LL_TIM_SetCounterMode(TIMx, LL_TIM_COUNTERMODE_CENTER_UP);
//使能自动重载预装载
LL_TIM_EnableARRPreload(TIMx);
if (Channel == LL_TIM_CHANNEL_CH1 || Channel == LL_TIM_CHANNEL_CH1N)
//设置比较值
LL_TIM_OC_SetCompareCH1(TIMx, 1000 - 1);
//设置成PWM模式
LL_TIM_OC_SetMode(TIMx, LL_TIM_CHANNEL_CH1, LL_TIM_OCMODE_PWM1);
//设置捕获/比较寄存器值
LL_TIM_OC_EnablePreload(TIMx, LL_TIM_CHANNEL_CH1);
if (Channel == LL_TIM_CHANNEL_CH2 || Channel == LL_TIM_CHANNEL_CH2N)
//设置比较值
LL_TIM_OC_SetCompareCH2(TIMx, 1000 - 1);
//设置成PWM模式
LL_TIM_OC_SetMode(TIMx, LL_TIM_CHANNEL_CH2, LL_TIM_OCMODE_PWM1);
//设置捕获/比较寄存器值
LL_TIM_OC_EnablePreload(TIMx, LL_TIM_CHANNEL_CH2);
//设置输出极性
LL_TIM_OC_SetPolarity(TIMx, Channel, LL_TIM_OCPOLARITY_HIGH);
//使能输出
LL_TIM_EnableAllOutputs(TIMx);
LL_TIM_CC_EnableChannel(TIMx, Channel);
//GPIO初始化
gpio_init();
void Stepper::gpio_init()
if (TIMx == TIM1)
//开启GPIO时钟
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOA);
//GPIO选为AF
//M1-DIR
LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
GPIO_InitStruct.Mode = LL_GPIO_MODE_OUTPUT;
GPIO_InitStruct.OutputType = LL_GPIO_OUTPUT_PUSHPULL;
GPIO_InitStruct.Pin = LL_GPIO_PIN_9;
GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
GPIO_InitStruct.Speed = LL_GPIO_SPEED_FREQ_MEDIUM;
LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
//M1-STEP
GPIO_InitStruct.Alternate = LL_GPIO_AF_1;
GPIO_InitStruct.Mode = LL_GPIO_MODE_ALTERNATE;
GPIO_InitStruct.Pin = LL_GPIO_PIN_8;
if (TIMx == TIM2)
//开启GPIO时钟
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOB);
LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOC);
//GPIO选为AF
//M2-DIR
GPIO_InitStruct.Pin = LL_GPIO_PIN_7;
LL_GPIO_Init(GPIOC, &GPIO_InitStruct);
//M2-STEP
GPIO_InitStruct.Pin = LL_GPIO_PIN_3;
LL_GPIO_Init(GPIOB, &GPIO_InitStruct);
void Stepper::begin()
LL_TIM_EnableCounter(TIMx);
void Stepper::stop()
LL_TIM_DisableCounter(TIMx);
void Stepper::setDirection(DIRCTION dir)
if (dir == INV)
if (TIMx == TIM1)
LL_GPIO_WriteOutputPort(GPIOB, LL_GPIO_ReadOutputPort(GPIOB) & (~LL_GPIO_PIN_4));
if (TIMx == TIM2)
LL_GPIO_WriteOutputPort(GPIOB, LL_GPIO_ReadOutputPort(GPIOB) & (~LL_GPIO_PIN_10));
if (dir == POS)
if (TIMx == TIM1)
LL_GPIO_WriteOutputPort(GPIOB, LL_GPIO_ReadOutputPort(GPIOB) | (LL_GPIO_PIN_4));
if (TIMx == TIM2)
LL_GPIO_WriteOutputPort(GPIOB, LL_GPIO_ReadOutputPort(GPIOB) | (LL_GPIO_PIN_10));
void Stepper::setFreq(uint16_t freq)
if (freq == 0)
return;
else if (!LL_TIM_IsEnabledCounter(TIMx))
uint32_t ARR_t = TIMx_freq / TIMx_prescaler / freq;
if (ARR_t > 65535) //触碰上限——频率过低
TIMx_prescaler *= 10; //提高分频比
if (ARR_t < 2) //触碰下限——频率过高
TIMx_prescaler /= 10; //降低分频比
LL_TIM_SetPrescaler(TIMx, TIMx_prescaler);
LL_TIM_SetAutoReload(TIMx, ARR_t);
uint16_t CCR_t = ARR_t * 0.5;
if (Channel == LL_TIM_CHANNEL_CH1)
LL_TIM_OC_SetCompareCH1(TIMx, CCR_t);
if (Channel == LL_TIM_CHANNEL_CH2)
LL_TIM_OC_SetCompareCH2(TIMx, CCR_t);
* @brief 设置转速
* @param speed 转速-单位(度/秒)
void Stepper::setSpeed(float speed)
//判断速度方向
DIRCTION _dir = POS;
if (speed != abs(speed))
_dir = INV;
speed = abs(speed);
setDirection(_dir);
//速度限幅
if (speed > 5000)
speed = 5000;
if (speed < 10)
speed = 10;
this- >speed = speed;
//将速度转化为定时器频率
uint16_t _freq = speed / 1.8;
setFreq(_freq);
float Stepper::getSpeed()
return speed;
