【FireBeetle 2 ESP32-S3开发板测评】MicroPython开发体验 https://wiki.dfrobot.com/SKU_DFR0975_FireBeetle_2_Board_ESP32_S3#target_7
https://micropython.org/download/GENERIC_S3_SPIRAM_OCT/
https://dfimg.dfrobot.com/nobody/wiki/9ff8b49e14a932851f4a783e6c49a7f2.zip
打开flash_download_tool_3.9.3.exe
按照如下设置
按住boot按键,按一下rst重启
点击ERASE
点击START
按rst重启,打开USB枚举的串口即可pyhton脚本操作
双击打开thonny.exe
Run配置解释器
输入如下代码
import time
from machine import Pin
led=Pin(21,Pin.OUT)
while True:
led.value(1)
time.sleep(1)
led.value(0)
time.sleep(1)
保存
运行
可以看到绿色LED闪烁
