TQA40i_CoreB核心板+底板平台芯片:全志A40I
内核版本:linux-3.10
操作系统:Linux
ADC移植调试步骤:
1、驱动使用
内核自带ADC驱动,驱动
位置:lichee/linux-3.10/drivers/hwmon/adcxx.c
注:该驱动适配1转2、4、8路ADC。
2、设备树配置
spi2: spi@01c17000 { compatible = "allwinner,sun8i-spi"; clock-frequency = <1000000>; status = "ok"; spidev@0 { #address-cells = <1>; #size-cells = <1>; compatible = "adcxx8s"; //转多少路就对应多少,此处是1转8, reg = <0>; spi-max-frequency = <100000>; status = "ok"; }; };
3、查看ADC值
编译后即可在系统/sys/class/hwmon/hwmon1/device内查看到对应节点生成,cat即可获取对应通道adc值
