LTM4626是一款完整的12A降压开关模式µModule(微型模块)稳压器,采用小型6.25mm × 6.25mm × 3.87mm BGA封装。封装中包含开关控制器、功率FET、电感和支持元件。在3.1V至20V的输入电压范围内工作时,LTM4626支持通过单个外部电阻设置的0.6V至5.5V输出电压范围。其高效率设计提供高达12A的连续输出电流。只需要输入和输出体电容。
LTM4626支持可选断续工作模式和用于供电轨顺序的输出电压跟踪。其高开关频率和电流模式控制可在不牺牲效率的情况下对线路和负载变化作出超快的瞬态响应。
故障保护特性包括过压、过流和过热保护。
LTM4626提供SnPb或符合RoHS标准的端子表面。
在 <1cm2(单面 PCB)或 0.5cm2(双面 PCB)的空间内提供完整的解决方案
6.25mm × 6.25mm × 3.87mm BGA 封装
宽输入电压范围:3.1V 至 20V
0.6V 至 5.5V 输出电压
12A 直流输出电流
整个线路、负载和温度范围内的最大总直流输出电压误差为 ±1.5%
差分远程感应放大器
电流模式控制,快速瞬态响应
外部频率同步
与多个 LTM4626 多相并联均流
输出电压跟踪
可选择的不连续模式
电源正常指示器
过压、过流和过热保护
应用
电信、数据通信、网络和工业设备
医疗诊断设备
数据存储机架单元和卡片
测试与调试系统
LTM4705EY#PBF LTM4642EY#PBF LTM4620EV#PBF LTM4653EY#PBF
LTM8060EY#PBF LTM8003IY#PBF LTM4620EV#PBF LTM4662EY#PBF
LTM4655EY#PBF LTM8053EY#PBF LTM8029EY#PBF LTM4662EY#PBF
LTM4681EY#PBF LTM4632EV#PBF LTM8026EV#PBF LTM4678EY#PBF
LTM8051EY#PBF LTM4650EY-1B#PBF LTM8052EV#PBF LTM4678EY#PBF
LTM4657EY#PBF LTM4650EY-1B#PBF LTM8052AEV#PBF LTM4686EV#PBF
LTM4664EY#PBF LTM8064EY#PBF LTM4613EV#PBF LTM4686EV#PBF
LTM4664EY#PBF LTM4636EY#PBF LTM4628EV#PBF LTM4686EV-1#PBF
LTM4668EY#PBF LTM4647EY#PBF LTM4618EV#PBF LTM4686EV-1#PBF
LTM4668AEY#PBF LTM4650EY#PBF LTM4627EV#PBF LTM4645EY#PBF
LTM4671EY#PBF LTM4650IY#PBF LTM4611EV#PBF LTM8063EY#PBF
LTM4691EV#PBF LTM4630EY-1B#PBF LTM8033EV#PBF LTM8065EY#PBF
LTM8024EY#PBF LTM4630EY-1B#PBF LTM8027EV#PBF LTM4622AEV#PBF
LTM8024EY#PBF LTM4630AIV#PBF LTM8031EV#PBF LTM4622AEV#PBF
LTM4680EY#PBF LTM4630AIV#PBF LTM4615EV#PBF LTM4636EY-1#PBF
LTM4680EY#PBF LTM4622IV#PBF LTM4619EV#PBF LTM4650AEY#PBF
LTM4700EY#PBF LTM4622IV#PBF LTM8025EV#PBF LTM4650AEY-1#PBF
LTM4700EY#PBF LTM4675EY#PBF LTM4604AEV#PBF LTM8073EY#PBF
LTM8002IY#PBF LTM4675EY#PBF LTM4606EV#PBF LTM4643EV#PBF
LTM8071EY#PBF LTM4676AEY#PBF LTM4608AEY#PBF LTM4631EV#PBF
LTM8074EY#PBF LTM4676AEY#PBF LTM4612EV#PBF LTM4631EV#PBF
LTM8078EY#PBF LTM4625EY#PBF LTM4616EY#PBF LTM4642EY#PBF
LTM8078EY#PBF LTM4648EY#PBF LTM8021EV#PBF LTM4630EV#PBF
LTM4626EY#PBF LTM4677EY#PBF LTM4601AHVEV#PBF LTM8050EY#PBF
LTM4638EY#PBF LTM4677EY#PBF LTM4614EV#PBF LTM4637EV#PBF
LTM4646EY#PBF LTM4634EY#PBF LTM8032EV#PBF LTM4649EY#PBF
LTM4646EY#PBF LTM4623EV#PBF LTM4601AEV-1#PBF LTM8028EY#PBF
LTM4600EV#PBF LTM4639EY#PBF LTM8020EV#PBF LTM4620AEV#PBF
LTM4600HVEV#PBF LTM4644EY#PBF LTM4603HVEV#PBF LTM4620AEV#PBF
LTM4601EV#PBF LTM4624EY#PBF LTM4603EV-1#PBF LTM4641EY#PBF
LTM4601HVEV#PBF LTM4630EV#PBF LTM8022EV#PBF LTM8001EY#PBF
LTM4602EV#PBF LTM4602HVEV#PBF LTM8023EV#PBF LTM4633EY#PBF
