TBP-9160 无风扇嵌入式系统
1、支持LGA 1151针6代/7代Intel Xeon/Core i7/i5/i3系列处理器;
2、Intel C236芯片组;
3、支持-40°C to 75°C工作温度;
4、可选4路千兆PoE+ 4 IEEE 802.3at网口,支持硬件Bypass模式;
5、板载2路千兆RJ45 LAN, iAMT 11.0;
6、前置3个SIM卡槽、支持3G/4G/LTE/WiFi/GPRS/UMTS;
7、扩展插槽 : 3个Mini PCIe/mSATA, 1 M.2;
8、存储:2个2.5" 硬盘位,支持HDD/SSD、1个CFast卡槽
9、其他I/O:16pin GPIO, 8个USB 3.0, 4个COM;
10、电源:6V to 36V DC-in、支持80V过压保护、远程开关控制;
11、显示接口:DVI-I+DVI-D+DisplayPort display(最大支持4K显示);
12、尺寸:260mm x 215mm x 79mm,重量:4.2kg。
| 系统信息 | |
| 处理器 | LGA 1151针6th/7th Intel Xeon/Core i7/i5/i3系列处理器 |
| 芯片组 | Intel C236 |
| BIOS | AMI |
| SIO | IT8786E |
| 内存 | 2根DDR4 2400/2133 MHz SO-DIMM插槽,最大支持64GB |
| I/O信息 | |
| 串口 | 4个COM RS-232/422/485 |
| USB | - 8个USB 3.0 (外置) - 1个USB 2.0 (内置) |
| 数字输入输出 | 16pin GPIO |
| 指示灯 | 电源指示灯、硬盘指示灯、无线网络指示灯, PoE网口指示灯 |
| SIM卡槽 | 3个SIM Card Socket (外置) |
| 扩展插槽 | |
| Mini PCIe | 3个全长Mini-PCIE插槽、支持PCIe/USB/External SIM Card/mSATA |
| M.2 | 1 M.2 Socket (Key ID : M) |
| 显示 | |
| 显卡芯片 | Intel HD Graphics P630/630/P530/530 |
| 接口 | - DVI-I : Up to 1920 x1200 @ 60 Hz - DVI-D : Up to 1920 x1200 @ 60Hz - DisplayPort : Up to 4096 x 2304 @ 60Hz |
| 存储 | |
| SATA | 2 SATA III (6Gbps) support S/W RAID 0, 1 |
| mSATA | 3 SATA III (Mini PCIe Type, 6Gbps) |
| 存储设备 | - 1个CFast Socket, Push-in/Push-out Ejector - 2 个前置2.5" SSD/HDD Tray |
| 音频 | |
| Audio Codec | Realtek ALC892, 5.1 Channel HD Audio |
| Audio Interface | 1 Mic-in, 1 Line-out |
| 网络 | |
| LAN 1 | Intel I219LM GigE LAN supports iAMT 11.0 |
| LAN 2 | Intel I210 GigE LAN |
| 可选网络 | |
| LAN 3 | GigE IEEE 802.3at (25.5W/48V) PoE+ by Intel I210, supporting LAN bypass mode |
| LAN 4 | GigE IEEE 802.3at (25.5W/48V) PoE+ by Intel I210, supporting LAN bypass mode |
| LAN 5 | GigE IEEE 802.3at (25.5W/48V) PoE+ by Intel I210, supporting LAN bypass mode |
| LAN 6 | GigE IEEE 802.3at (25.5W/48V) PoE+ by Intel I210, supporting LAN bypass mode |
| 电源 | |
| Power Input | 6V to 36V, DC-in |
| Power Interface | 3-pin Terminal Block : V+, V-, Frame Ground |
| Ignition Control | 16 Mode (Internal) |
| Remote Switch | 3-pin Terminal Block |
| Surge Protection | Up to 80V/1ms Transient Power |
| 其他 | |
| 安全管理 | 可选Infineon SLB9665 supports TPM 2.0, LPC Interface |
| 看门狗 | Reset : 1 to 255 sec./min. per step |
| 智能管理 | Wake on LAN, PXE supported |
| HW Monitor | Monitoring temperature, voltages. Auto throttling control when CPU overheats. |
| 支持系统 | |
| OS | Windows 10, Windows 8.1, Windows 7, Linux |
| 机械 | |
| 尺寸(W x L x H) | 260mm x 215mm x 79mm (10.2” x 8.5” x 3.1”) |
| 重量 | 4.2 kg (9.26 lb) |
| 安装方式 | - 壁挂式安装 - 导轨安装 - 2U安装支架 (可选) |
| 环境 | |
| 工作环境 | 35W TDP CPU : - Core i7, i5, i3 : -40°C to 75°C (-40°F to 167°F) - Xeon E3-1268L v5 : -40°C to 70°C (-40°F to 158°F) 65W TDP CPU : Core i7, i5, i3 : -40°C to 55°C (-40°F to 131°F) 80W TDP CPU : Xeon E3-1275 v6, E3-1275 v5, E3-1225 v5 : -40°C to 45°C (-40°F to 113°F) |
| 存储温度 | -40°C to 85°C (-40°F to 185°F) |
| 湿度 | 5% to 95% Humidity, non-condensing |
| 相对湿度 | 95% at 75°C |
| 冲击 | - IEC 60068-2-27 - SSD : 50G @ wallmount, Half-sine, 11ms |
| 振动 | - IEC 60068-2-64 - SSD : 5Grms, 5Hz to 500Hz, 3 Axis |
| 认证 | E13, CE, FCC, EN50155, EN50121-3-2 |
