一位来自深圳的客户向东沃电子寻求帮助:“直插式压敏电阻07D821K和07D821KJ这两者之间,有什么区别?”根据型号可以判断出,07D821K和07D821KJ属于07D系列直插式压敏电阻,根据直插式压敏电阻型号命名规律,如下图,会发现:
07:压敏电阻陶瓷片的直径07mm;D:Disk, S:Square;821代表压敏电阻电压;K:±10%, L:±15%;J:High Surge & High Energy。由此可见,07D821K和07D821KJ,属于07D系列,他们之间区别在于前者是常规型压敏电阻,后者是高通流高能量压敏电阻。直插式压敏电阻根据直径可分为:05D、07D、10D、14D、20D、25D。接下来,压敏电阻厂家东沃电子从特性、应用、型号三方面带您认识07D系列直插压敏电阻。
07D系列直插压敏电阻特性
* Wide operating voltage (V1mA) range from 18V to 820V.
* Fast responding to transient over-voltage.
* Large absorbing transient energy capability.
* Low clamping ratio and no follow-on current.
* Meets MSL level 1, per J-STD-020.
* Insulation Resistance: > 100MΩ.
* Safety number : CUL- E317616 VDE- 40028836 CQC-12001076478 ISO9001-2018.
07D系列直插压敏电阻应用
* Transistor, Diode, IC, Thyristor or Triac semiconductor protection.
* Surge protection in consumer electronics.
* Surge protection in industrial electronics.
* Surge protection in electronic home appliances, gas and petroleum appliances.
* Relay and electromagnetic valve surge absorption.
07D系列直插压敏电阻型号
常规型:07D180L、07D220K、07D270K、07D330K、07D390K、07D470K、07D560K、07D680K、07D820K、07D101K、07D121K、07D151K、07D181K、07D201K、07D221K、07D241K、07D271K、07D301K、07D331K、07D361K、07D391K、07D431K、07D471K、07D511K、07D561K、07D621K、07D681K、07D751K、07D781K、07D821K;
高浪涌/能量型:07D180LJ、07D220KJ、07D270KJ、07D330KJ、07D390KJ、07D470KJ、07D560KJ、07D680KJ、07D820KJ、07D101KJ、07D121KJ、07D151KJ、07D181KJ、07D201KJ、07D221KJ、07D241KJ、07D271KJ、07D301KJ、07D331KJ、07D361KJ、07D391KJ、07D431KJ、07D471KJ、07D511KJ、07D561KJ、07D621KJ、07D681KJ、07D751KJ、07D781KJ、07D821KJ;
在实际应用中,具体选用什么型号的压敏电阻为电路安全护航,还需要根据电路情况和保护需求来确定。压敏电阻选型是一门学问,专业的事情找专业的人做。压敏电阻选型,东沃电子从电路保护方案设计、器件选型、免费样品、批量试产一站式为您服务!
