/kernel/include/linux/leds.h // 重要,led相关结构体,宏定义,trigger等
目录 /kernel/driver/leds/ 下
led-class.c // 定义led class及相关接口
led-core.c // export 了闪烁,设置亮灭等接口
led-gpio.c // "leds-gpio" 驱动
leds.h // 提供几个接口,如:led_init_core
led-triggers.c // export了许多接口,包括:led_trigger_register
目录 /kernel/driver/leds/trigger 下
ledtrig-backlight.c
ledtrig-camera.c
ledtrig-cpu.c
ledtrig-default-on.c
ledtrig-disk.c
ledtrig-gpio.c
ledtrig-heartbeat.c // 心跳灯效果
ledtrig-mtd.c
ledtrig-oneshot.c
ledtrig-panic.c
ledtrig-timer.c // 定时器
ledtrig-transient.c
以参考上面的trigger例子写自己的trigger,或者改造,需要在make menuconfig里面选上才会编译,如下:
步骤 一 : dts配置
① leds节点是在rk3588-evb.dtsi文件中定义
#include "rk3588-evb.dtsi"
② 定义四个led节点: (检查gpio是否被复用)
使用命令:dmesg | grep cannot检查是否有gpio冲突,有冲突的话驱动代码会中断,后面的dts就不会生效。
&leds {
status = "okay";
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = < &work1_led_gpio >, < &work2_led_gpio >,< &work3_led_gpio >,< &work4_led_gpio >;
work1_led: work1{
default-state = "off";
gpios = < &gpio4 RK_PD2 GPIO_ACTIVE_HIGH >;
work2_led: work2{
gpios = < &gpio4 RK_PD3 GPIO_ACTIVE_HIGH >;
work3_led: work3{
gpios = < &gpio4 RK_PD4 GPIO_ACTIVE_HIGH >;
work4_led: work4{
gpios = < &gpio4 RK_PD5 GPIO_ACTIVE_HIGH >;
&pinctrl {
leds{
work1_led_gpio: work1-led-gpio{
rockchip,pins = < 4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_down >;
work2_led_gpio: work2-led-gpio{
rockchip,pins = < 4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_down >;
work3_led_gpio: work3-led-gpio{
rockchip,pins = < 4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_down >;
work4_led_gpio: work4-led-gpio{
rockchip,pins = < 4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_down >;
步骤二:调试,验证:在用户空间操作led
使用了驱动框架后可以不需要编写应用程序就可以测试led是否能正常被点亮与熄灭,这些都可以在sysfs文件系统中完成。在装载驱动后可以在/sys/class/leds/目录下看到对应的led设备目录,如本文中的work1(填充设备时的设备名字段)。
brightness power uevent
max_brightness subsystem
echo 1 > brightness
echo 0 > brightness
