RT-Thread内核对象控制块详解
嵌入式技术
1357人已加入
背景
  • 学习RT-Thread,除了基础的应用,应该花点时间,研究下底层内核的实现方法。
  • RT-Thread内核,整体代码量不大,很适合研究,后期,打算在这个基础上,开发一些软件包。
  • 之前了解了一点数据结构的知识,主要为结构体、链表。不过感觉没有真正的使用起来。
  • 程序 = 数据结构+算法。
  • 万事开头难,先从最基本的概念开始。
内核对象控制块
  • 对象(object)结构体
嵌入式
  • 对象可以派生具体的对象
嵌入式
导火索
  • 今天,想仔细看看RT-Thread 的内核的对象,基本上都是结构体,看看结构体的大小,占用RAM的大小。
  • 单片机的程序,短小精悍是每个嵌入式软件工程师追求的,实现相同功能,占用最少资源,意味着硬件成本会进一步降低。
  • 编写一个函数,打印一下rt_object 等对象的结构体占用的内存(RAM)大小。
void print_kernel_object_size(void)
    struct rt_object obj;
    rt_kprintf("struct rt_object size=%d\\n", sizeof(obj));
    rt_kprintf("rt_list_t size=%d\\n", sizeof(rt_list_t));
    rt_kprintf("struct rt_timer size=%d\\n", sizeof(struct rt_timer));
    rt_kprintf("struct rt_thread size=%d\\n", sizeof(struct rt_thread));
    rt_kprintf("struct rt_ipc_object size=%d\\n", sizeof(struct rt_ipc_object));
    rt_kprintf("struct rt_semaphore size=%d\\n", sizeof(struct rt_semaphore));
    rt_kprintf("struct rt_mutex size=%d\\n", sizeof(struct rt_mutex));
    rt_kprintf("struct rt_event size=%d\\n", sizeof(struct rt_event));
    rt_kprintf("struct rt_mailbox size=%d\\n", sizeof(struct rt_mailbox));
    rt_kprintf("struct rt_messagequeue size=%d\\n", sizeof(struct rt_messagequeue));
    rt_kprintf("struct rt_mempool size=%d\\n", sizeof(struct rt_mempool));
    rt_kprintf("struct rt_device size=%d\\n", sizeof(struct rt_device));
    rt_kprintf("struct rt_device_graphic_info size=%d\\n", sizeof(struct rt_device_graphic_info));
MSH_CMD_EXPORT(print_kernel_object_size, print_kernel_object_size); //导出命令
  • 运行效果
msh / >pri
msh / >print_kernel_object_size
struct rt_object size=20
rt_list_t size=8
struct rt_timer size=44
struct rt_thread size=128
struct rt_ipc_object size=28
struct rt_semaphore size=32
struct rt_mutex size=36
struct rt_event size=32
struct rt_mailbox size=48
struct rt_messagequeue size=60
struct rt_mempool size=52
struct rt_device size=80
struct rt_device_graphic_info size=12
  • struct rt_object size=20,说明:RT_NAME_MAX为8时,内核对象大小为:20字节(8+ (4)+8 = 20)
  • 初步分析,rt_uint8_t type,rt_uint8_t flag,因为内存对齐,占用了2+2=4个字节。(Keil MDK5 armcc)
 * Base structure of Kernel object
struct rt_object
    char       name[RT_NAME_MAX];                       /**< name of kernel object */
    rt_uint8_t type;                                    /**< type of kernel object */
    rt_uint8_t flag;                                    /**< flag of kernel object */
#ifdef RT_USING_MODULE
    void      *module_id;                               /**< id of application module */
#endif
    rt_list_t  list;                                    /**< list node of kernel object */
  • 当我更改内核对象中的:rt_uint8_t type --> rt_uint32_t type,验证下结构体大小时,却发生了Assert 栈溢出。
嵌入式
- RT -     Thread Operating System
/ | \\     4.0.3 build Jan 16 2021
2006 - 2020 Copyright by rt-thread team
thread: stack overflow
  • 经过调试,发现是线程结构体引起的对齐问题。结构体,一定要注意结构与大小一致。
  • 线程控制块(结构体)rt_thread,使用了内核对象块,是重写的。
嵌入式
  • 看来,还是不要直接改基础的内核控制块。
  • 要改rt_object的结构体大小,其他对象派生的对象,都要注意下。
总结
  • 通过打印rt_object等结构体的大小,了解了rt_object的基本构成。
  • 基本了解到了其他内核对象,如rt_thread(线程控制块),rt_timer(定时器控制块),rt_list_t(双向链表)的RAM占用大小。
  • 了解到rt_object的派生方式,增加其他对象的特殊属性,构成其他的对象,用链表链接起来,用于OS管理。
