米尔瑞萨RZ/G2L开发板 TF卡读写速度测试 这里选取了三款TF卡进行测试
1、写的速度:
100+0 records in~# time dd if=/mnt/1.txt of=/dev/null bs=1M count=100 iflag=direc
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 4.17846 s, 25.1 MB/s
real 0m4.259s
user 0m0.001s
sys 0m0.658s
ynct@myir-yg2lx:~# time dd if=tempfile of=/mnt/1.txt bs=1M count=100 conv=fdatas
100+0 records in
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 4.24326 s, 24.7 MB/s
速度为24.7MB/s
2、读的速度:
root@myir-yg2lx:/# time dd if=/mnt/1.txt of=/dev/null bs=1M count=100 iflag=direct,nonblock
100+0 records in
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 1.88799 s, 55.5 MB/s
real 0m1.893s
user 0m0.005s
sys 0m0.062s
读的速度达到了55.5MB/s
插入SD卡后自动识别:
[ 4205.897770] mmc1: new high speed SDHC card at address ef6d
[ 4205.909758] mmcblk1: mmc1:ef6d AFGCC 14.8 GiB
[ 4205.927461] mmcblk1: p1 p2 p3
写的速度为24.7MB/s:
100+0 records out# time dd if=/mnt/1.txt of=/dev/null bs=1M count=100 iflag=direc
104857600 bytes (105 MB, 100 MiB) copied, 4.25149 s, 24.7 MB/s
real 0m4.332s
user 0m0.001s
读的速度为40MB/s
100+0 records in~# time dd if=tempfile of=/mnt/1.txt bs=1M count=100 conv=fdatasy
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 2.62025 s, 40.0 MB/s
real 0m2.625s
user 0m0.001s
sys 0m0.125s
插入后自动识别
root@myir-yg2lx:~# [ 4363.624406] mmc1: card ef6d removed
[ 4380.805766] mmc1: new high speed SDXC card at address 2143
[ 4380.812127] mmcblk1: mmc1:2143 APPSD 500 GiB
[ 4380.825030] Alternate GPT is invalid, using primary GPT.
[ 4380.830420] mmcblk1: p1 p2 p3
写入速度24.7MB/s:
[ 4380.8304g2lx:~# time dd if=tempfile of=/mnt/1.txt bs=1M count=100 conv=fdatasync
100+0 records in1.txt of=/dev/null bs=1M count=100 iflag=direc
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 4.24071 s, 24.7 MB/s
real 0m4.323s
user 0m0.001s
读取39MB/s:
syst@myir-yg2lx:~# time dd if=/mnt/1.txt of=/dev/null bs=1M count=100 iflag=direct,nonblock
100+0 records out
104857600 bytes (105 MB, 100 MiB) copied, 2.66665 s, 39.3 MB/s
real 0m2.671s
user 0m0.001s
sys 0m0.130s
终上所述TF卡的写入速度均为24.7MB/s,但是读取的速度还是以SD NAND速度为最快,达到了55.5MB/S。
