安科瑞 刘芳
咨询家:acrel-js
产品特点 Products Features
安装方便
Easy mounting
体积小,节省空间
Small size and space saving
无插入损耗
No insertion losses
抗干扰能力强
High immunity to external nterference
应用领域 Applications
电动汽车
EV Auto
交流变速驱动器
AC variable speed drives
直流电机驱动静态转换器
Static converters for DC motor drives
注意 Remarks
错误的接线可能导致传感器损坏。
The false wiring may result in the damage of the sensor.
Ip 方向与产品箭头方向一致时,输出电压为正极。
VOUT is positive when IP flows in the direction of the arrow.
当初级导体完全充满初级孔径时动态表现(di/dt 和响应时间)为最佳效果。
Dynamic performances (di/dt and response time) are best with a single bar completely filling the primary hole.
初级导体的温度不应超过 100℃。
Temperature of the primary conductor should not exceed 100°C.
这是一个标准的产品,需要其他规格(测量电流、电源电压、输出电压、连接器、转换比率等)请联系我们。
This is a standard model. For different versions (IP,supply voltages, output voltages,connection of secondary,turns ratios...),please contact us.
机械尺寸 Mechanical dimension
机械特性 Mechanical characteristics
绝对最大额定参数(不操作)Absolute Maximum ratings (not operating)
除非另有说明,否则环境参数均为@ TA = 25 °C
测量电流计算公式 Measurement of current calculation formula
