接口/总线/驱动
Pmod接口标准是由Xilinx的第三方合作伙伴迪芝伦(Digilent)制定的接口扩展规范,除了我们经常看到的FMC扩展接口,Pmod接口应用也越来越广泛,由于FPGA I/O接口的灵活性,Pmod接口非常适合FPGA开发板卡与外设实现连接。此外迪芝伦(Digilent)为了解决与特定微控制器接口的连接推出了不同引脚排列的类型。
1、连接器标准
Pmod接口分为HOST和和Peripheral两种类型,分为6pin、8pin和12pin等几类,详见“Digilent Pmod interface Specification Revision:November 20, 2011”。
2、I/O信号定义
针对不同应用,不用接口类型,其连接器的信号定义不同,详见下表
| 接口类型 | Pin Num | Signal | Direction |
| I2C Interface | 1/2 | SCL | |
| 3/4 | SDA | ||
| 5/6 | GND | ||
| 7/8 | VCC | ||
| Pmod Interface Type 1 (GPIO) | 1 | IO1 | In/Out |
| 2 | IO2 | In/Out | |
| 3 | IO3 | In/Out | |
| 4 | IO4 | In/Out | |
| 5 | GND | ||
| 6 | VCC | ||
| Pmod Interface Type 2 (SPI) | 1 | SS | Out |
| 2 | MOSI | Out | |
| 3 | MISO | In | |
| 4 | SCK | Out | |
| 5 | GND | ||
| 6 | VCC | ||
| Pmod Interface Type 2A (expanded SPI) | 1 | SS | Out |
| 2 | MOSI | Out | |
| 3 | MISO | In | |
| 4 | SCK | Out | |
| 5 | GND | ||
| 6 | VCC | ||
| 7 | INT | In | |
| 8 | RESET | Out | |
| 9 | N/S | not-specified | |
| 10 | N/S | not-specified | |
| 11 | GND | ||
| 12 | VCC | ||
| Pmod Interface Type 3 (UART) | 1 | CTS | Out |
| 2 | RTS | In | |
| 3 | RXD | In | |
| 4 | TXD | Out | |
| 5 | GND | ||
| 6 | VCC | ||
| Pmod Interface Type 4 (UART) | 1 | CTS | In |
| 2 | TXD | Out | |
| 3 | RXD | In | |
| 4 | RTS | Out | |
| 5 | GND | ||
| 6 | VCC | ||
| Pmod Interface Type 4A (expanded UART) | 1 | CTS | In |
| 2 | TXD | Out | |
| 3 | RXD | In | |
| 4 | RTS | Out | |
| 5 | GND | ||
| 6 | VCC | ||
| 7 | INT | In | |
| 8 | RESET | Out | |
| 9 | N/S | ||
| 10 | N/S | ||
| 11 | GND | ||
| 12 | VCC | ||
| Pmod Interface Type 5 (H-Bridge) | 1 | DIR | Out |
| 2 | EN | Out | |
| 3 | SA | In | |
| 4 | SB | In | |
| 5 | GND | ||
| 6 | VCC | ||
| Pmod Interface Type 6 (dual H-Bridge) | 1 | DIR1 | Out |
| 2 | EN1 | Out | |
| 3 | DIR2 | Out | |
| 4 | EN2 | Out | |
| 5 | GND | ||
| 6 | VCC |
注:‘Out’means from the host to the peripheral; ‘In’ means from the peripheral to thehost. 详细信息参见接口标准:“Digilent Pmod interface Specification Revision:November 20, 2011”。
编辑:黄飞
