基于SpringBoot+Redis等技术实现转盘抽奖活动项目,含前端、后台及数据库文件
SpringBoot
Redis
Mybaits
application.yml
server:
port: 8080 #端口号
servlet:
context-path: /
spring:
datasource:
druid:
url: jdbc:mysql://127.0.0.1:3366/lottery?useUnicode=true&characterEncoding=utf-8&useSSL=false #数据库端口号:3366 数据库名:lottery
username: root #数据库用户名
password: root #数据库密码
driver-class-name: com.mysql.cj.jdbc.Driver
initial-size: 30
max-active: 100
min-idle: 10
max-wait: 60000
time-between-eviction-runs-millis: 60000
min-evictable-idle-time-millis: 300000
validation-query: SELECT 1 FROM DUAL
test-while-idle: true
test-on-borrow: false
test-on-return: false
filters: stat,wall
redis:
port: 6379 #redis 端口号 无密码
host: 127.0.0.1
lettuce:
pool:
max-active: -1
max-idle: 2000
max-wait: -1
min-idle: 1
time-between-eviction-runs: 5000
mvc:
view:
prefix: classpath:/templates/
suffix: .html
# mybatis-plus
mybatis-plus:
configuration:
map-underscore-to-camel-case: true
auto-mapping-behavior: full
mapper-locations: classpath*:mapper/**/*Mapper.xml
# 线程池
async:
executor:
thread:
core-pool-size: 6
max-pool-size: 12
queue-capacity: 100000
name-prefix: lottery-service-
https://gitee.com/javanoteany/lottery.git
