编程语言及工具
上一期介绍了使用量化软件BDF进行Ir(ppy)3的第一激发三重态T1的结构优化和频率计算的过程,这一期将介绍基于T1激发态结构,做S0和T1之间的旋轨耦合SOC计算,以及基于BDF的量化计算结果,使用MOMAP进行Ir(ppy)3的磷光辐射速率计算的过程。将Irppy3_t1_soc.xyz拖入Device Studio中,选择Simulator → BDF → BDF,界面中设置参数。在Basic Settings界面中的Calculation Type选择TDDFT-SOC,Functional选择PBE0泛函,取消勾选Use Dispersion Correction。Hamiltonian选择sf-X2C,Basis选择All Electron类型下的x2c-SVPall基组。
在TDDFT Settings面板中的Spin-Orbit Coupling内容框中,勾选Including Ground State。
Basic Settings、SCF Settings和TDDFT Settings界面中的其它参数使用推荐的默认值,不需要做修改。之后点击 Generate files 即可生成对应计算的输入文件。选中生成的bdf.inp文件,右击选择open with,打开该文件,如下所示:
生成的输入文件bdf.inp为:
$compass
Title
C33H24IrN3
Geometry
Ir 0.00713728 0.02772384 0.06844143
C 2.49525480 -1.44901550 -0.61634342
C 2.18832036 0.30085414 -2.14613715
C 3.68634391 -1.80881598 -1.26572189
C 1.93194560 -2.11689507 0.55823360
C 3.35838993 -0.00562745 -2.82371008
H 1.54555778 1.13535498 -2.43828056
C 4.11644203 -1.08671356 -2.36826137
H 4.27131594 -2.65056635 -0.89578008
C 2.53568350 -3.23676194 1.15281696
H 3.66807719 0.59265321 -3.68133337
H 5.04582829 -1.36185464 -2.87261245
C 0.15985754 -2.20796738 2.19060975
C 1.95468524 -3.83725789 2.26057143
H 3.46642195 -3.64596142 0.75209976
C 0.76249168 -3.31842902 2.77624738
H -0.76777546 -1.81381956 2.61329025
H 2.42616559 -4.70662835 2.72403490
H 0.30108846 -3.78788394 3.64972555
C -1.72817262 0.21988877 1.05055833
C -2.80684294 -0.57231379 0.57552059
C -1.98377973 1.07446424 2.13652018
C -4.07348283 -0.50293868 1.17614116
C -2.51722058 -1.44616477 -0.55935718
C -3.24105830 1.13344573 2.72846833
H -1.17254967 1.69178400 2.52835606
C -4.29332764 0.34509124 2.25152758
H -4.89835191 -1.11318655 0.80076906
C -3.42583030 -2.33456215 -1.15446765
H -3.40666531 1.80444608 3.57586125
H -5.27935385 0.39610056 2.71819787
C -0.85701735 -2.13799807 -2.04878703
C -3.02057249 -3.12865176 -2.21547404
H -4.44525950 -2.39959511 -0.77498376
C -1.70631730 -3.03592701 -2.67708275
H 0.18295061 -2.02278722 -2.36320870
H -3.72428268 -3.82273458 -2.68079359
H -1.34337957 -3.64618310 -3.50492143
N -1.25281508 -1.36491844 -1.03498749
C 0.05749757 2.91146589 -0.57266019
C -1.32777267 1.80183369 -2.13392316
C -0.20378718 4.13789922 -1.23242992
C 0.84833732 2.74053836 0.60027467
C -1.62207960 2.97568834 -2.79963588
H -1.76529074 0.85235254 -2.45705603
C -1.02279371 4.18710974 -2.33345870
H 0.25619858 5.05119985 -0.85064151
C 0.99228869 1.37116718 1.10523883
C 1.50408647 3.78492491 1.29091760
H -2.29824567 2.96275978 -3.65460398
H -1.21968527 5.13470889 -2.83803374
C 1.79964050 1.14876807 2.23660070
C 2.27478596 3.51131149 2.40946142
H 1.40861651 4.81693355 0.94742301
C 2.43450283 2.19478112 2.89597172
H 1.90681894 0.12796182 2.60984200
H 2.77105978 4.33756351 2.92655136
H 3.04508359 2.00761950 3.78145402
N -0.50508694 1.73366277 -1.08285477
N 1.77567220 -0.40171722 -1.08777429
C 0.72548984 -1.57229627 1.07484738
End Geometry
Basis
x2c-SVPall
Skeleton
Group
C(1)
$end
$xuanyuan
Heff
21
Hsoc
2
Direct
$end
$scf
RKS
Charge
SpinMulti
1
DFT
PBE0
MPEC+COSX
Molden
$end
$tddft
Imethod
1
Isf
Idiag
1
Iroot
6
MPEC+COSX
Istore
1
$end
$tddft
Imethod
1
Isf
1
Idiag
1
Iroot
6
MPEC+COSX
Istore
2
$end
$tddft
Isoc
2
Nfiles
2
Ifgs
1
Imatsoc
-1
Imatrsf
-1
Imatrso
-2
$end
选中bdf.inp文件,右击选择Run提交作业,任务结束后bdf.out,bdf.scf.molden结果文件会出现在Project中。选择bdf.out,右击选择show view,在TDDFT面板中,选择Spinor,在Dominant Excitations中确定第2、3和4为T1态的三个分量。
点击bdf.out文件,右击选择Open Containing Folder进入所在文件夹,打开bdf.out,查找‘[tddft_soc_matrso]:’,输出了考虑SOC之后各激发态相对于基态的能量和跃迁偶极矩。
其中,1 1 表示基态固有偶极矩;1 2 表示第一个与第二个旋量态间的跃迁偶极矩,以此类推。这里需要第2、3和4激发态的激发能和跃迁偶极矩数据。
激发能在E_J-E_I列下读取,分别为2.201474871 eV,2.210597826 eV和2.538843563 eV。转换为以au单位分别为0.080902668 a.u., 0.081237931 a.u.和0.093300733 a.u.。
跃迁偶极矩的数据在‘Details of transition dipole moment with SOC (in a.u.):’中列出,前三列为单位为au的偶极矩数据,后三列为单位为Debye的偶极矩数据。
将debye单位下六个数的平方之和开方,得到该态的跃迁偶极矩。另一种方法为将Norm后的三个数平方之和开方,再乘以2.5417。得到第2、3和4激发态的跃迁偶极矩为0.04778347 Debye, 0.408818358 Debye和0.998260011 Debye。
得到的这6个参数将用于MOMAP软件的磷光发射速率的计算中。
至此,MOMAP对Ir(ppy)3的磷光辐射速率计算需要的BDF量化软件的结构优化频率结果文件、旋轨耦合计算结果文件和参数部分都已完成。
接下来开始使用MOMAP进行Ir(ppy)3的磷光辐射速率的计算。
首先计算T1→S0的磷光辐射速率,第一步为做电子振动耦合(electron-vibration coupling, EVC)计算,该计算基于量化计算输出的分子振动频率、力常数矩阵,同时在内坐标以及直角坐标系下,计算分子跃迁发生初末态间的模式位移、黄昆因子、重整能以及Duschinsky转动矩阵。
将BDF软件计算得到的Ir(ppy)3的基态的优化频率计算文件改名为irppy3_s0.out,和T1优化频率计算文件改名为irppy3_t1.out,同时放在EVC计算文件夹中。
EVC计算的输入文件momap.inp为:
do_evc=1
&evc
ffreq(1)="irppy3_s0.out"
ffreq(2)="irppy3_t1.out"
proj_reorg=.t.
提交脚本文件momap.slurm运行任务。任务正常结束后,使用evc.cart.dat进行接下来的T1→S0磷光发射速率计算。对T1的三个态依次进行计算,其中第一个子态,即第2个态的磷光发射速率,输入文件momap.inp为:
do_spec_tvcf_ft = 1
do_spec_tvcf_spec = 1
&spec_tvcf
DUSHIN = .t.
Temp = 300 K
tmax = 1000 fs
dt = 1 fs
Ead = 0.080902668 au
EDMA = 1 debye
EDME = 0.04778347 debye
FreqScale = 1
DSFile = "evc.cart.dat"
Emax = 0.3 au
dE = 0.00001 au
logFile = "spec.tvcf.log"
FtFile = "spec.tvcf.ft.dat"
FoFile = "spec.tvcf.fo.dat"
FoSFile = "spec.tvcf.spec.dat"
提交脚本文件momap.slurm运行任务。任务结束后,确认关联函数是否收敛。
打开spec.tvcf.log,文件末尾输出了第2个态的磷光辐射速率值,如图所示:
磷光辐射速率在第一个数和第二个数读取,单位分别为a.u.和s-1,第三个数为寿命,单位为ns。这里为 7.55493312E+03 /s。
第二个子态,即第3个态的磷光发射速率,输入文件momap.inp为:
do_spec_tvcf_ft = 1
&spec_tvcf
DUSHIN = .t.
Temp = 300 K
tmax = 1000 fs
dt = 1 fs
Ead = 0.081237931 au
EDMA = 1 debye
EDME = 0.408818358 debye
FreqScale = 1
Emax = 0.3 au
dE = 0.00001 au
打开spec.tvcf.log,文件末尾输出了第3个态的磷光辐射速率值,如图所示:
磷光辐射速率为 5.57755602E+05 /s。
第三个子态,即第4个态的磷光发射速率,输入文件momap.inp为:
do_spec_tvcf_ft = 1
&spec_tvcf
DUSHIN = .t.
Temp = 300 K
tmax = 1000 fs
dt = 1 fs
Ead = 0.093300733 au
EDMA = 1 debye
EDME = 0.998260011 debye
FreqScale = 1
Emax = 0.3 au
dE = 0.00001 au
打开spec.tvcf.log,文件末尾输出了第4个态的磷光辐射速率值,如图所示:
磷光辐射速率为 4.46922190E+06 /s。
根据三个子态E_J-E_I能量的玻尔兹曼分布,得到第2个态占58.73%,第3个态占41.27%,第4个态占0%。
因此对三个子态的磷光发射速率乘以相应的比例,加和得到T1态的磷光发射速率为2.346119845E+05 /s。
编辑:黄飞
