mkdir mytools && cd mytools
sudo apt install curl
curl https://gitee.com/oschina/repo/raw/fork_flow/repo-py3 > ~/mytools/repo
| chmod +x repo |
| echo 'export PATH=~/mytools:$PATH' >> ~/.bashrc |
| source ~/.bashrc |
| wget https://repo.huaweicloud.com/har ... 3/linux/gn.1523.tar |
tar -xvf gn.1523.tar
tar -xvf ninja.1.9.0.tar
tar -xvf llvm-linux-9.0.0-34042.tar
tar -xvf hc-gen-0.65-linux.tar
tar -xvf gcc_riscv32-linux-7.3.0.tar.gz
echo 'export PATH=~/mytools/gn:$PATH' >> ~/.bashrc
| echo 'export PATH=~/mytools/ninja:$PATH' >> ~/.bashrc |
| echo 'export PATH=~/mytools/llvm/bin:$PATH' >> ~/.bashrc |
| echo 'export PATH=~/mytools/hc-gen:$PATH' >> ~/.bashrc |
| echo 'export PATH=~/mytools/gcc_riscv32/bin:$PATH' >> ~/.bashrc |
#更新环境变量
source ~/.bashrc
sudo apt-get install dosfstools mtools
mkdir -p ~/harmonyos && cd ~/harmonyos
#如果首次使用git,需要设置用户名和邮箱
#git config --global user.name "yourname"
#git config --global user.email "your-email-address"
repo init -u https://gitee.com/openharmony/manifest.git -b master --no-repo-verify
#拉取远程代码
repo sync -c
pip3 install vritualenv
#创建使用 python3.8 为默认 python 解释器的 virtualenv
mkdir ~/harmonyos/venv && virtualenv -p python3.8 ~/harmonyos/venv
#激活 virtualenv ,这样Python环境可以与本地版本互不影响。
#使用deactivate可退出虚拟环境。
source ~/harmonyos/venv/bin/activate
#安装 setuptools 和 kconfiglib
pip3 install setuptools kconfiglib
#安装编译 hi3861 需要的 pip 包
pip3 install scons ecdsa pycryptodome
pip3 install --upgrade --ignore-installed six
python3 build.py wifiiot
