在这篇文章中,我们将在服务器端使用内存来存储客户端发送过来的数据。在实现数据存储之前,我们先在客户端使用Clap库来解析命令行参数,并封装成命令发送给服务器。
Clap解析命令行参数 在Cargo.toml文件中加入clap依赖:
clap = {version = "3.1", features = ["derive"]}
在src目录下新建args.rs文件,写入以下代码:
1use clap::Parser;
2
3#[derive(Debug, Parser)]
4#[clap(name = "kv_client")]
5pub enum ClientArgs {
6 Get {
7 #[clap(long)]
8 key: String,
9 },
10 Set {
11 #[clap(long)]
12 key: String,
13 #[clap(long)]
14 value: String,
15 },
16 Publish {
17 #[clap(long)]
18 topic: String,
19 #[clap(long)]
20 value: String,
21 },
22 Subscribe {
23 #[clap(long)]
24 topic: String,
25 },
26 Unsubscribe {
27 #[clap(long)]
28 topic: String,
29 #[clap(long)]
30 id: u32,
31 }
32}
在src/lib.rs中加入以下代码:
1mod args; 2pub use args::*;修改src/bin/kv_client.rs代码:
1#[tokio::main] 2async fn main() -> Result<(), Box> { 3 ...... 4 5 let client_args = ClientArgs::parse(); 6 7 // 解析命令行参数,生成命令 8 let cmd = process_args(client_args).await?; 9 // 命令编码 10 cmd.encode(&mut buf).unwrap(); 11 // 发送命令 12 stream.send(buf.freeze()).await.unwrap(); 13 info!("Send command successed!"); 14 15 loop { 16 tokio::select! { 17 Some(Ok(buf)) = stream.next() => { 18 let cmd_res = CmdResponse::decode(&buf[..]).unwrap(); 19 info!("Receive a response: {:?}", cmd_res); 20 } 21 } 22 } 23}
1// 生成CmdRequest命令 2async fn process_args(client_args: ClientArgs) -> Result> { 3 match client_args { 4 // 生成 GET 命令 5 ClientArgs::Get{key} => { 6 Ok(CmdRequest::get(key)) 7 }, 8 // 生成 SET 命令 9 ClientArgs::Set{key, value} => { 10 Ok(CmdRequest::set(key, value.into())) 11 }, 12 // 生成 PUBLISH 命令 13 ClientArgs::Publish{ topic, value } => { 14 Ok(CmdRequest::publish(topic, value.into())) 15 }, 16 // 生成 SUBSCRIBE 命令 17 ClientArgs::Subscribe{ topic } => { 18 Ok(CmdRequest::subscribe(topic)) 19 }, 20 // 生成 UNSUBSCRIBE 命令 21 ClientArgs::Unsubscribe{topic, id} => { 22 Ok(CmdRequest::unsubscribe(topic, id)) 23 } 24 } 25}
打开一个终端,启动kv_sever。打开另一个终端执行以下命令来测试客户端:
RUST_LOG=info cargo run --bin kv_client get --key mykeyRUST_LOG=info cargo run --bin kv_client set --key mykey --value myvalue
服务器和客户端都正常处理了收到的请求和响应。
内存存储
我们使用dashmap crate在内存中存储数据,dashmap是一个快速的并发map。
我们先创建src/storage目录,再创建src/storage/mod.rs文件,然后在src/lib.rs文件中引入storage模块。
在src/storage/mod.rs文件中定义一个storage trait,以便于以后不同存储方式的扩展,代码如下:
1use std::Error;
2
3use bytes::Bytes;
4
5pub trait Storage {
6 fn get(&self, key: &str) -> Result
在src/storage目录下创建mem_storage.rs文件:
1#[derive(Clone, Debug, Default)]
2pub struct MemStorage {
3 map: DashMap
4}
5
6impl MemStorage {
7 pub fn new() -> Self {
8 Self {
9 map: Default::default(),
10 }
11 }
12}
13
14impl Storage for MemStorage {
15 fn get(&self, key: &str) -> Result
修改kv_server.rs代码:
1async fn main() -> Result<(), Box> { 2 ...... 3 4 // 初始化内存存储 5 let storage = Arc::new(MemStorage::new()); 6 7 loop { 8 ...... 9 10 let stor = storage.clone(); 11 12 tokio::spawn(async move { 13 // 使用Frame的LengthDelimitedCodec进行编解码操作 14 let mut stream = Framed::new(stream, LengthDelimitedCodec::new()); 15 while let Some(Ok(mut buf)) = stream.next().await { 16 // 对客户端发来的protobuf请求命令进行拆包 17 let cmd_req = CmdRequest::decode(&buf[..]).unwrap(); 18 info!("Receive a command: {:?}", cmd_req); 19 20 // 处理请求命令 21 let cmd_res = process_cmd(cmd_req, &stor).await.unwrap(); 22 23 buf.clear(); 24 25 // 对protobuf的请求响应进行封包,然后发送给客户端。 26 cmd_res.encode(&mut buf).unwrap(); 27 stream.send(buf.freeze()).await.unwrap(); 28 } 29 info!("Client {:?} disconnected", addr); 30 }); 31 } 32} 33 34// 处理请求命令,返回Response 35async fn process_cmd(req: CmdRequest, storage: &MemStorage) -> Result > { 36 match req { 37 // 处理 GET 命令 38 CmdRequest{ 39 req_data:Get(Get {key})), 40 } => { 41 let value = storage.get(&key)?; 42 Ok(CmdResponse::new(200, "get success".to_string(), value.unwrap_or_default())) 43 }, 44 // 处理 SET 命令 45 CmdRequest{ 46 req_data:Set(Set {key, value})), 47 } => { 48 let value = storage.set(&key, value)?; 49 Ok(CmdResponse::new(200, "set success".to_string(), value.unwrap_or_default())) 50 }, 51 _ => Err("Invalid command".into()) 52 } 53}
测试
1,打开一个终端,运行kv_server:
RUST_LOG=info cargo run --bin kv_server
2,打开一个终端,运行kv_client,执行set命令:
执行结果:
INFO kv_client: Send command successed!
INFO kv_client: Receive a response: CmdResponse { status: 200, message: "get success", value: b"myvalue" }
审核编辑:刘清
