一、概述
Hadoop 是 Apache 软件基金会下一个开源分布式计算平台,以 HDFS(Hadoop Distributed File System)、MapReduce(Hadoop2.0 加入了 YARN,Yarn 是资源调度框架,能够细粒度的管理和调度任务,还能够支持其他的计算框架,比如 spark)为核心的 Hadoop 为用户提供了系统底层细节透明的分布式基础架构。hdfs 的高容错性、高伸缩性、高效性等优点让用户可以将 Hadoop 部署在低廉的硬件上,形成分布式系统。
HDFS
YARN
二、开始部署
1)添加源
地址:
https://artifacthub.io/packages/helm/apache-hadoop-helm/hadoop
helm repo add apache-hadoop-helm https://pfisterer.github.io/apache-hadoop-helm/ helm pull apache-hadoop-helm/hadoop --version 1.2.0 tar -xf hadoop-1.2.0.tgz
2)构建镜像 Dockerfile
FROM myharbor.com/bigdata/centos:7.9.2009
RUN rm -f /etc/localtime && ln -sv /usr/share/zoneinfo/Asia/Shanghai /etc/localtime && echo "Asia/Shanghai" > /etc/timezone
RUN export LANG=zh_CN.UTF-8
# 创建用户和用户组,跟yaml编排里的spec.template.spec.containers. securityContext.runAsUser: 9999
RUN groupadd --system --gid=9999 admin && useradd --system --home-dir /home/admin --uid=9999 --gid=admin admin
# 安装sudo
RUN yum -y install sudo ; chmod 640 /etc/sudoers
# 给admin添加sudo权限
RUN echo "admin ALL=(ALL) NOPASSWD: ALL" >> /etc/sudoers
RUN yum -y install install net-tools telnet wget
RUN mkdir /opt/apache/
ADD jdk-8u212-linux-x64.tar.gz /opt/apache/
ENV JAVA_HOME=/opt/apache/jdk1.8.0_212
ENV PATH=$JAVA_HOME/bin:$PATH
ENV HADOOP_VERSION 3.3.2
ENV HADOOP_HOME=/opt/apache/hadoop
ENV HADOOP_COMMON_HOME=${HADOOP_HOME}
HADOOP_HDFS_HOME=${HADOOP_HOME}
HADOOP_MAPRED_HOME=${HADOOP_HOME}
HADOOP_YARN_HOME=${HADOOP_HOME}
HADOOP_CONF_DIR=${HADOOP_HOME}/etc/hadoop
PATH=${PATH}:${HADOOP_HOME}/bin
#RUN curl --silent --output /tmp/hadoop.tgz https://ftp-stud.hs-esslingen.de/pub/Mirrors/ftp.apache.org/dist/hadoop/common/hadoop-${HADOOP_VERSION}/hadoop-${HADOOP_VERSION}.tar.gz && tar --directory /opt/apache -xzf /tmp/hadoop.tgz && rm /tmp/hadoop.tgz
ADD hadoop-${HADOOP_VERSION}.tar.gz /opt/apache
RUN ln -s /opt/apache/hadoop-${HADOOP_VERSION} ${HADOOP_HOME}
RUN chown -R admin:admin /opt/apache
WORKDIR $HADOOP_HOME
# Hdfs ports
EXPOSE 50010 50020 50070 50075 50090 8020 9000
# Mapred ports
EXPOSE 19888
#Yarn ports
EXPOSE 8030 8031 8032 8033 8040 8042 8088
#Other ports
EXPOSE 49707 2122
开始构建镜像
docker build -t myharbor.com/bigdata/hadoop:3.3.2 . --no-cache ### 参数解释 # -t:指定镜像名称 # . :当前目录Dockerfile # -f:指定Dockerfile路径 # --no-cache:不缓存
推送到镜像仓库
docker push myharbor.com/bigdata/hadoop:3.3.2
调整目录结构
mkdir hadoop/templates/hdfs hadoop/templates/yarn mv hadoop/templates/hdfs-* hadoop/templates/hdfs/ mv hadoop/templates/yarn-* hadoop/templates/yarn/
2)修改配置
hadoop/values.yaml
image: repository: myharbor.com/bigdata/hadoop tag: 3.3.2 pullPolicy: IfNotPresent ... persistence: nameNode: enabled: true storageClass: "hadoop-nn-local-storage" accessMode: ReadWriteOnce size: 10Gi local: - name: hadoop-nn-0 host: "local-168-182-110" path: "/opt/bigdata/servers/hadoop/nn/data/data1" dataNode: enabled: true storageClass: "hadoop-dn-local-storage" accessMode: ReadWriteOnce size: 20Gi local: - name: hadoop-dn-0 host: "local-168-182-110" path: "/opt/bigdata/servers/hadoop/dn/data/data1" - name: hadoop-dn-1 host: "local-168-182-110" path: "/opt/bigdata/servers/hadoop/dn/data/data2" - name: hadoop-dn-2 host: "local-168-182-110" path: "/opt/bigdata/servers/hadoop/dn/data/data3" - name: hadoop-dn-3 host: "local-168-182-111" path: "/opt/bigdata/servers/hadoop/dn/data/data1" - name: hadoop-dn-4 host: "local-168-182-111" path: "/opt/bigdata/servers/hadoop/dn/data/data2" - name: hadoop-dn-5 host: "local-168-182-111" path: "/opt/bigdata/servers/hadoop/dn/data/data3" - name: hadoop-dn-6 host: "local-168-182-112" path: "/opt/bigdata/servers/hadoop/dn/data/data1" - name: hadoop-dn-7 host: "local-168-182-112" path: "/opt/bigdata/servers/hadoop/dn/data/data2" - name: hadoop-dn-8 host: "local-168-182-112" path: "/opt/bigdata/servers/hadoop/dn/data/data3" ... service: nameNode: type: NodePort ports: dfs: 9000 webhdfs: 9870 nodePorts: dfs: 30900 webhdfs: 30870 dataNode: type: NodePort ports: dfs: 9000 webhdfs: 9864 nodePorts: dfs: 30901 webhdfs: 30864 resourceManager: type: NodePort ports: web: 8088 nodePorts: web: 30088 ... securityContext: runAsUser: 9999 privileged: true
hadoop/templates/hdfs/hdfs-nn-pv.yaml
{{- range .Values.persistence.nameNode.local }}
apiVersion: v1
kind: PersistentVolume
metadata:
name: {{ .name }}
labels:
name: {{ .name }}
spec:
storageClassName: {{ $.Values.persistence.nameNode.storageClass }}
capacity:
storage: {{ $.Values.persistence.nameNode.size }}
accessModes:
- ReadWriteOnce
local:
path: {{ .path }}
nodeAffinity:
required:
nodeSelectorTerms:
- matchExpressions:
- key: kubernetes.io/hostname
operator: In
values:
- {{ .host }}
{{- end }}
hadoop/templates/hdfs/hdfs-dn-pv.yaml
{{- range .Values.persistence.dataNode.local }}
apiVersion: v1
metadata:
name: {{ .name }}
labels:
name: {{ .name }}
spec:
storageClassName: {{ $.Values.persistence.dataNode.storageClass }}
capacity:
storage: {{ $.Values.persistence.dataNode.size }}
accessModes:
- ReadWriteOnce
local:
path: {{ .path }}
nodeAffinity:
required:
nodeSelectorTerms:
- matchExpressions:
operator: In
values:
- {{ .host }}
{{- end }}
修改 hdfs service
mv hadoop/templates/hdfs/hdfs-nn-svc.yaml hadoop/templates/hdfs/hdfs-nn-svc-headless.yaml mv hadoop/templates/hdfs/hdfs-dn-svc.yaml hadoop/templates/hdfs/hdfs-dn-svc-headless.yaml # 注意修改名称,不要重复
# A headless service to create DNS records
apiVersion: v1
kind: Service
metadata:
name: {{ include "hadoop.fullname" . }}-hdfs-nn
labels:
app.kubernetes.io/name: {{ include "hadoop.name" . }}
helm.sh/chart: {{ include "hadoop.chart" . }}
app.kubernetes.io/instance: {{ .Release.Name }}
app.kubernetes.io/component: hdfs-nn
spec:
ports:
- name: dfs
port: {{ .Values.service.nameNode.ports.dfs }}
protocol: TCP
nodePort: {{ .Values.service.nameNode.nodePorts.dfs }}
- name: webhdfs
port: {{ .Values.service.nameNode.ports.webhdfs }}
nodePort: {{ .Values.service.nameNode.nodePorts.webhdfs }}
type: {{ .Values.service.nameNode.type }}
selector:
apiVersion: v1
kind: Service
metadata:
name: {{ include "hadoop.fullname" . }}-hdfs-dn
labels:
spec:
ports:
- name: dfs
port: {{ .Values.service.dataNode.ports.dfs }}
protocol: TCP
nodePort: {{ .Values.service.dataNode.nodePorts.dfs }}
- name: webhdfs
port: {{ .Values.service.dataNode.ports.webhdfs }}
nodePort: {{ .Values.service.dataNode.nodePorts.webhdfs }}
type: {{ .Values.service.dataNode.type }}
selector:
app.kubernetes.io/component: hdfs-dn
修改 yarn service
mv hadoop/templates/yarn/yarn-nm-svc.yaml hadoop/templates/yarn/yarn-nm-svc-headless.yaml mv hadoop/templates/yarn/yarn-rm-svc.yaml hadoop/templates/yarn/yarn-rm-svc-headless.yaml mv hadoop/templates/yarn/yarn-ui-svc.yaml hadoop/templates/yarn/yarn-rm-svc.yaml # 注意修改名称,不要重复
# Service to access the yarn web ui
apiVersion: v1
kind: Service
metadata:
name: {{ include "hadoop.fullname" . }}-yarn-rm
labels:
app.kubernetes.io/component: yarn-rm
spec:
ports:
- port: {{ .Values.service.resourceManager.ports.web }}
nodePort: {{ .Values.service.resourceManager.nodePorts.web }}
type: {{ .Values.service.resourceManager.type }}
selector:
修改控制器
在所有控制中新增如下内容:
containers:
securityContext:
runAsUser: {{ .Values.securityContext.runAsUser }}
privileged: {{ .Values.securityContext.privileged }}
hadoop/templates/hadoop-configmap.yaml
### 1、将/root换成/opt/apache
### 2、TMP_URL="http://{{ include "hadoop.fullname" . }}-yarn-rm-headless:8088/ws/v1/cluster/info"
3)开始安装
# 创建存储目录
mkdir -p /opt/bigdata/servers/hadoop/{nn,dn}/data/data{1..3}
helm install hadoop ./hadoop -n hadoop --create-namespace
NOTES
NAME: hadoop LAST DEPLOYED: Sat Sep 24 1755 2022 NAMESPACE: hadoop STATUS: deployed REVISION: 1 TEST SUITE: None NOTES: 1. You can check the status of HDFS by running this command: kubectl exec -n hadoop -it hadoop-hadoop-hdfs-nn-0 -- /opt/hadoop/bin/hdfs dfsadmin -report 2. You can list the yarn nodes by running this command: kubectl exec -n hadoop -it hadoop-hadoop-yarn-rm-0 -- /opt/hadoop/bin/yarn node -list 3. Create a port-forward to the yarn resource manager UI: kubectl port-forward -n hadoop hadoop-hadoop-yarn-rm-0 8088:8088 Then open the ui in your browser: open http://localhost:8088 4. You can run included hadoop tests like this: kubectl exec -n hadoop -it hadoop-hadoop-yarn-nm-0 -- /opt/hadoop/bin/hadoop jar /opt/hadoop/share/hadoop/mapreduce/hadoop-mapreduce-client-jobclient-3.3.2-tests.jar TestDFSIO -write -nrFiles 5 -fileSize 128MB -resFile /tmp/TestDFSIOwrite.txt 5. You can list the mapreduce jobs like this: kubectl exec -n hadoop -it hadoop-hadoop-yarn-rm-0 -- /opt/hadoop/bin/mapred job -list 6. This chart can also be used with the zeppelin chart helm install --namespace hadoop --set hadoop.useConfigMap=true,hadoop.configMapName=hadoop-hadoop stable/zeppelin 7. You can scale the number of yarn nodes like this: helm upgrade hadoop --set yarn.nodeManager.replicas=4 stable/hadoop Make sure to update the values.yaml if you want to make this permanent.
kubectl get pods,svc -n hadoop -owide
hdfs web:
http://192.168.182.110:30870/
yarn web:
http://192.168.182.110:30088/
5)测试验证
HDFS 测试验证
kubectl exec -it hadoop-hadoop-hdfs-nn-0 -n hadoop -- bash [root@local-168-182-110 hadoop]# kubectl exec -it hadoop-hadoop-hdfs-nn-0 -n hadoop -- bash bash-4.2$ bash-4.2$ bash-4.2$ hdfs dfs -mkdir /tmp bash-4.2$ hdfs dfs -ls / Found 1 items drwxr-xr-x - admin supergroup 0 2022-09-24 17:56 /tmp bash-4.2$ echo "test hadoop" >test.txt bash-4.2$ hdfs dfs -put test.txt /tmp/ bash-4.2$ hdfs dfs -ls /tmp/ Found 1 items -rw-r--r-- 3 admin supergroup 12 2022-09-24 17:57 /tmp/test.txt bash-4.2$ hdfs dfs -cat /tmp/ cat: `/tmp': Is a directory bash-4.2$ hdfs dfs -cat /tmp/test.txt test hadoop bash-4.2$
Yarn 的测试验证等后面讲到 hive on k8s 再来测试验证。
6)卸载
helm uninstall hadoop -n hadoop
kubectl delete pod -n hadoop `kubectl get pod -n hadoop|awk 'NR>1{print $1}'` --force
kubectl patch ns hadoop -p '{"metadata":{"finalizers":null}}'
kubectl delete ns hadoop --force
这里也提供 git 下载地址,有需要的小伙伴可以下载部署玩玩:
https://gitee.com/hadoop-bigdata/hadoop-on-k8s
在 k8s 集群中 yarn 会慢慢被弱化,直接使用 k8s 资源调度,而不再使用 yarn 去调度资源了,这里只是部署了单点,仅限于测试环境使用,下一篇文章会讲 Hadoop 高可用 on k8s 实现,请小伙伴耐心等待,有任何疑问欢迎给我留言~
