嵌入式技术
在嵌入式Linux开发中,有时候为了定位问题,需要查看某个进程的各个线程的运行情况。
multi_thread.c:
左右滑动查看全部代码>>>
#define _GNU_SOURCE
#include
#include
#include
#include
// 线程名称最大长度
#define APP_THREAD_NAME_MAX_LEN 32
// 线程索引
typedef enum _app_thread_index
APP_THREAD_INDEX_TEST0,
APP_THREAD_INDEX_TEST1,
APP_THREAD_INDEX_TEST2,
APP_THREAD_INDEX_TEST3,
APP_THREAD_INDEX_TEST4,
APP_THREAD_INDEX_TEST5,
APP_THREAD_INDEX_MAX
}app_thread_index_e;
// 线程入口函数指针类型
typedef void *(*p_thread_fun)(void *param);
// 线程数据表
typedef struct _app_thread
pthread_t thread_handle;
p_thread_fun thread_entry;
char name[APP_THREAD_NAME_MAX_LEN];
}app_thread_s;
static void *test0_thread_entry(void *param);
static void *test1_thread_entry(void *param);
static void *test2_thread_entry(void *param);
static void *test3_thread_entry(void *param);
static void *test4_thread_entry(void *param);
static void *test5_thread_entry(void *param);
// 线程表
app_thread_s s_app_thread_table[APP_THREAD_INDEX_MAX] =
{0, test0_thread_entry, "test0_thread"},
{0, test1_thread_entry, "test1_thread"},
{0, test2_thread_entry, "test2_thread"},
{0, test3_thread_entry, "test3_thread"},
{0, test4_thread_entry, "test4_thread"},
{0, test5_thread_entry, "test5_thread"}
printf("test0_thread running...
while (1)
usleep(2 * 1000);
return NULL;
printf("test1_thread running...
while (1)
usleep(2 * 1000);
return NULL;
printf("test2_thread running...
while (1)
usleep(2 * 1000);
return NULL;
printf("test3_thread running...
while (1)
usleep(2 * 1000);
return NULL;
printf("test4_thread running...
while (1)
usleep(2 * 1000);
return NULL;
printf("test5_thread running...
while (1)
usleep(2 * 1000);
return NULL;
static int create_all_app_thread(void)
int ret = 0;
for (int i = 0; i < APP_THREAD_INDEX_MAX; i++)
ret = pthread_create(&s_app_thread_table[i].thread_handle, NULL, s_app_thread_table[i].thread_entry, NULL);
if (0 != ret)
printf("%s thread create error! thread_id = %ld
", s_app_thread_table[i].name, s_app_thread_table[i].thread_handle);
return ret;
else
printf("%s thread create success! thread_id = %ld
pthread_setname_np(s_app_thread_table[i].thread_handle, s_app_thread_table[i].name);
pthread_detach(s_app_thread_table[i].thread_handle);
return ret;
int main(int argc, char **argv)
create_all_app_thread();
while (1)
usleep(2 * 1000);
return 0;
我们可以通过top命令来查看,具体做法就是要在top输出中开启线程查看,请调用top命令的“-H”选项,该选项会列出所有Linux线程。
这里我们指定查看multi_thread进程的各线程运行情况,命令:
top -H -p `pidof multi_thread`
注意:这里的 `号并不是单引号!!!
这个符号在键盘上感叹号!键的左边。
我们先运行程序,再使用top命令查看,比如:
注意:我们创建线程的时候需要使用 pthread_setname_np 函数设置线程的名字,否则top -H显示不出来具体的线程。
假如我们把上例中的pthread_setname_np屏蔽掉,结果如下:
可见,不调用pthread_setname_np设置线程名称的话,top -H查看得到的各线程名称就是进程名。
以上就是本次的分享,期待大家的三连支持!全部0条评论
