type-c/DP转双路MIPI信号转换芯片LT7911D方案介绍
Description
The LT7911D is a high peRFormance DP1.2 to MIPI®DSI/CSI chip for VR/Smart phone/display application.
For DP1.2 input, LT7911D can be configured as 1,2,4 lane, also support lane swap function. Adaptive equalization makes it suitable for long cable application and the maximum bandwidth is up to 21.6Gbps.
For MIPI®DSI/CSI output, LT7911D features configurable single-port or dual-port or MIPI®DSI/CSI with 1 high-speed clock lane and 1~4 high-speed data lanes operating at maximum 1.5Gb/s/lane, which can support a total bandwidth of up to 12Gbps. LT7911D supports burst mode DSI video data transferring, also support flexible video data mapping path.
With sophisticated MCU and the Embedded Flash, LT7911D support EDID buffer, DP/eDP input detection and determine to enter into power saving mode automatically. When the receiver of LT7911D locks the input signal, MCU can read the recovered timing parameters by MSA registers to match the ASSR. The DPCD registers are accessible via system I2C when debugging the full link training. Once the fast link training used, system time will save at least 400ms.
2. Features
• Type-C
• DP/eDP Receiver
• Single/Dual-Port LVDS Transmitter
• Miscellaneous
3. Applications
• Mobile system
• VR
