LINEAR稳压降压-升压电荷泵接受超出、等于或少于输出电压的输入电压,并可用作将输入电压增高或减少至稳定的输出电压。由于不再采用电感器,这些开关电容变换器可用作开关调节器拓扑的代替品,从而减少解决方案的规格并优化设计。LINEAR稳压降压-升压电荷泵主要特点包括:低静态电流、多模式运转、自动模式转换以维持调节电压、输出高达500mA的Iout、低噪声恒频运转和Burst Mode®运转、超温、设备故障和短路保护。
深圳市立维创展科技是ADI \ LINEAR的代理商,以代理分销库存现货ADI \ LINEAR为产品优势,可提供当日发货服务,欢迎咨询。
详情了解LINEAR电源模块请点击:http://www.leadwaytk.com/public/brand/19.html
或联系我们的销售工程师:0755-83050846 QQ: 331206974
| 产品型号 | Number of Outputs | Vin (min) | Vin (max) | Output Current (typ) | Output Voltage | Isupply (typ) |
| V | V | A | A | |||
| LTC3245 | 1 | 2.7 | 38 | 250m | 5V or Adjustable (2.5V to 5V), Fixed 3.3V | 18µ |
| LTC3246 | 1 | 2.7 | 38 | 500m | 5V or Adjustable (2.5V to 5V), Fixed 3.3V | 20µ |
| LTC3221 | 1 | 1.8 | 5.5 | 60m | 3.3V, 5V, Adj | 8µ |
| LTC3240 | 1 | 1.8 | 5.5 | 150m | 2.5V, 3.3V | 65µ |
| LTC3204-3.3 | 1 | 1.8 | 4.5 | 50m | 3.3V | 48µ |
| LTC3204-5 | 1 | 2.7 | 5.5 | 150m | 5V | 48µ |
| LTC3204B-3.3 | 1 | 1.8 | 4.5 | 50m | 3.3V | 48µ |
| LTC3204B-5 | 1 | 2.7 | 5.5 | 150m | 5V | 48µ |
| LTC1555L | 1 | 2.6 | 6.6 | 20m | 3V, 5V | 40µ |
| LTC1555L-1.8 | 1 | 2.6 | 6.6 | 20m | 1.8V, 3V, 5V | 32µ |
| LTC1754-3.3 | 1 | 2 | 4 | 40m | 3.3V | 13µ |
| LTC1754-5 | 1 | 2 | 4 | 40m | 5V | 13µ |
| LTC1755 | 1 | 2.7 | 6 | 60m | 3V, 5V | 60µ |
| LTC1756 | 1 | 2.7 | 6 | 60m | 3V, 5V | 60µ |
| LTC1517-3.3 | 1 | 2.2 | 4.4 | 15m | 3.3V | 6µ |
| LTC1514 | 1 | 2.7 | 10 | 50m | 3.3, 5V | 60µ |
| LTC1515 | 1 | 2.7 | 10 | 50m | 3.3V, 5V | 60µ |
| LTC1555 | 1 | 2.7 | 10 | 20m | 5V | 60µ |
| LTC1556 | 1 | 2.7 | 10 | 20m | 5V | 60µ |
