ARCH是台湾著名的电源模块电源制造商。ARCH主要提供大功率AC-DC和DC-DC电源模块,这些模块电源经常使用于系统前端。目前,ARCH的电源模块用户涵盖显示器、仪器仪表设备、医疗设备、机械自动化、医疗、城市轨道交通等各个领域,ARCH的电源模块具备大功率、小体积的特点。
ARCH工业模块电源模块AIC是一种安装在PCB上的开关电源模块。模块电源具备完全密封性的塑料外壳和低纹波和噪音,通用性输入范围为90-264VAC,47-63Hz,超紧凑型规格尺寸为1.41x0.75x0.86英寸,最大空载功率<;3W,隔离等级II,具备CE和UL安全认证。
除非另有要求,否则所有的标准规范在标称输入电流电压、满载和预热后25°C时合理有效。深圳市立维创展科技授权代理ARCH电源模块产品,提供高效率,高品质与小尺寸特性的产品满足市场趋势和需求,并提供技术支持服务,欢迎咨询。
详情了解ARCH(翊嘉)电源模块请点击:http://www.leadwaytk.com/public/brand/38.html
或咨询我们的销售工程师:0755-83050846 QQ:3312069749
| Input Specifications / 輸入規格 | ||
| Voltage | 90~264 VAC or 120~370 VDC | |
| Frequency | 47-63 Hz | |
| Inrush Current (<500us) |
20 A (115 VAC) / 50 A (230 VAC) |
(max.) |
| Leakage Current | 0.25 mA | (max.) |
| Output Specifications / 輸出規格 | ||
| Power | 3 | (max.) |
| Voltage | 3.3, 5, 9, 12, 15, 24 | |
Voltage Accuracy (Full Load and Nominal Vin) |
±10% | |
| Minimum Load | 0% (at Full Load) | |
Line Regulation (LL to HL at Full Load) |
3.3S:±5% --------------------------------- others:±2% |
(typ.) |
Load Regulation (0% to 100% at Full Load) |
(typ.) |
| Ripple & Noise |
3.3S:<250mV (Vp-p) --------------------------------- 5S:<200mV (Vp-p) --------------------------------- 9S:<150mV (Vp-p) --------------------------------- 12S,15S,24S:<100mV (Vp-p) |
(max.) |
| Protection / 保護規格 | ||
| Over Power Protection | Hiccup technique, auto-recovery | |
| Over Voltage Protection | Zener diode clamp | |
| Short Circuit Protection |
Hiccup mode, indefinite (automatic recovery) |
| Environment Specification / 環境規格 | ||
| Operating Temperature | -40 °C to +85 °C | |
| Storage Temperature | -40 °C to +85 °C | |
| Temperature Coefficient | ±0.02% / °C | |
| Humidity | 95% RH | |
| SAFETY & EMC | ||
Isolation Voltage (Input to Output) |
3750 VAC | |
| Agency Approvals | UL / IEC / EN 60950-1 | |
EMI (Conducted & Radiated Emission) |
EN 55032 class B | |
EMS (Noise Immunity) |
EN 55024 | |
| Others / 其他 | ||
Dimensions (Tolerance ±0.5mm) |
35.7 x 19.0 x 22.0 mm 1.41 x 0.75 x 0.86 inches |
| Weight | 19.9 g | |
| Case Material |
Plastic resin with Fiberglass (flammability to UL 94V-0) |
| Cooling Method | Free air convection |
