PULSAR模拟电压控制衰减器系列在32分贝到64分贝的使用范围内是无反射的。PULSAR采用PIN二极管,工作频率使用范围为0.25-16ghz。它们在0至+8VDC的操作电流电压下工作,最大输入功率为+27DBM。PULSAR模拟电压控制衰减器是双向的:任何的SMA端口可适用于输入。
特性
操作电流电压:0至+8V(典型);
工作功率:<=0DBM;
功率处理:最大+27DBM;
工作温度:-25°C到+80°C;
深圳市立维创展科技授权代理销售PULSAR微波产品,并提供售后支持服务,欢迎咨询。
详情了解UMS放大器请点击:http://www.leadwaytk.com/public/brand/36.html
或联系我们的销售工程师:0755-83642657 QQ: 2295048674
| Frequency Range | Attenuation | Insertion | VSWR | Connector | P/N | |
| (GHz) | Range | Loss | max. | Type | ||
| Min | Max | (dB) | (dB) max. | |||
| 0.25 | 0.5 | 32 | 2.5 | 1.50:1 | SMA | AAT-10-479/1S |
| 0.25 | 0.5 | 64 | 3 | 1.70:1 | SMA | AAT-11-479/1S |
| 0.5 | 1 | 32 | 2.6 | 1.60:1 | SMA | AAT-12-479/1S |
| 0.5 | 1 | 64 | 3.1 | 1.80:1 | SMA | AAT-13-479/1S |
| 0.5 | 2 | 32 | 3 | 1.80:1 | SMA | AAT-14-479/1S |
| 0.5 | 2 | 64 | 3.5 | 1.80:1 | SMA | AAT-15-479/1S |
| 1 | 2 | 32 | 3.2 | 1.80:1 | SMA | AAT-16-479/3S |
| 1 | 2 | 64 | 3.7 | 1.80:1 | SMA | AAT-17-479/3S |
| 1 | 4 | 32 | 3.5 | 1.80:1 | SMA | AAT-18-479/3S |
| 1 | 4 | 64 | 5 | 1.80:1 | SMA | AAT-19-479/1S |
| 2 | 4 | 32 | 3.5 | 1.80:1 | SMA | AAT-20-479/3S |
| 2 | 4 | 64 | 4.5 | 1.80:1 | SMA | AAT-21-479/3S |
| 2 | 8 | 32 | 4 | 2.00:1 | SMA | AAT-22-479/2S |
| 2 | 8 | 64 | 5.5 | 2.00:1 | SMA | AAT-23-479/3S |
| 4 | 8 | 32 | 4 | 1.90:1 | SMA | AAT-24-479/2S |
| 4 | 8 | 64 | 5 | 1.90:1 | SMA | AAT-25-479/2S |
| 8 | 12.4 | 32 | 4 | 2.00:1 | SMA | AAT-26-479/4S |
| 8 | 12.4 | 64 | 5 | 2.00:1 | SMA | AAT-27-479/4S |
| 6 | 16 | 32 | 4 | 2.00:1 | SMA | AAT-28-479/5S |
| 6 | 16 | 64 | 5 | 2.00:1 | SMA | AAT-29-479/5S |
