Qorvo在提供不同频率和功率水平的各种功率放大器解决方案方面拥有丰富的经验。Qorvo的功率放大器满足移动应用、商业基础设施以及各种军事和航天系统的严格系统要求。Qorvo放大器技术和产品继续帮助客户改进尺寸、重量和功率,并推动下一代性能。
深圳市立维创展科技是QORVO的经销商,主要提供QORVO功率放大器, IC和裸芯片,立维创展拥有稳定的供应渠道,价格优势,并大量备有现货库存,欢迎咨询。
| 型号 |
频率最小值 GHz |
频率最大值 GHz |
Pout dBm |
Psat dBm |
增益 dB |
PAE % |
OIP3 dBm |
电压 V |
电流 mA |
封装类型 |
| CMD184 | 0.5 | 20 | 34.5 | 36.5 | 13 | 42 | -2.8 to 28 | 700 | Die | |
| CMD216 | 14 | 18 | 37 | 38 | 16 | 43 | 28 | 550 | Die | |
| CMD217 | 28 | 32 | 36.7 | 39.3 | 20 | 41 | 28 | 580 | Die | |
| CMD262 | 26 | 28 | 37.5 | 38.5 | 26 | 43 | 28 | 400 | Die | |
| QPA1000 | 2.8 | 3.2 | 47 | 25 | 58 | 25 | 200 | QFN | ||
| QPA1001 | 3.1 | 3.5 | 48 | 25 | 54 | 30 | 200 | QFN | ||
| QPA1003D | 1 | 8 | 40 | 30 | 30 | 28 | 650 | Die | ||
| QPA1003P | 1 | 8 | 40 | 30 | 30 | 28 | 650 | |||
| QPA1006D | 10.7 | 12.7 | 46 | 17 | 39 | 20 | 1,200 | Die | ||
| QPA1009D | 10.7 | 12.7 | 43.5 | 17 | 40 | 20 | 600 | Die | ||
| QPA1010 | 7.9 | 11 | 42 | 25 | 38 | 24 | 600 | QFN | ||
| QPA1010D | 7.9 | 11 | 42 | 25 | 38 | 24 | 600 | Die | ||
| QPA1011 | 7.9 | 11 | 44.5 | 26 | 37.5 | 24 | 1,200 | QFN | ||
| QPA1011D | 7.9 | 11 | 45 | 26 | 37 | 24 | 1,200 | Die | ||
| QPA1013D | 6 | 18 | > 40 | > 25 | > 20 | 20 | 1,250 | Die | ||
| QPA1014 | 2.7 | 3.7 | 46 | 48 | 28 | 450 | ||||
| QPA1017D | 5.7 | 7 | 47 | 28 | 4 | 24 | 1,500 | Die | ||
| QPA1019 | 4.5 | 7.0 | 40 | 30 | 40 | 22 | 290 | QFN | ||
| QPA1019D | 4.5 | 7 | 40 | 33.5 | 40 | 22 | 290 | Die | ||
| QPA1022 | 8.5 | 11 | 36.5 | 24.5 | 22 | 180 | ||||
| QPA1022D | 8.5 | 11 | 24 | 45 | 22 | 180 | Die | |||
| QPA1027 | 2.8 | 3.5 | 48 | 31 | 55 | 50 | 300 | QFN | ||
| QPA2210D | 27 | 31 | 38.4 | 16 | 32 | 20 | 200 | Die | ||
| QPA2211 | 27.5 | 31 | 41 | 17 | 26 | 22 | 280 | CP | ||
| QPA2211D | 27.5 | 31 | 41.5 | 17 | 34 | 22 | 280 | Die | ||
| QPA2211T | 27.5 | 31 | 41.5 | |||||||
| QPA2212D | 27.5 | 31 | 43.4 | |||||||
| QPA2212T | 27.5 | 31 | 43.4 | |||||||
| QPA2213D | 2 | 20 | 34 | 16 | 23 | 18 | 330 | |||
| QPA2226D | 34 | 36 | 43 | |||||||
| QPA2229D | 34 | 36 | 41.2 | 41.2 | 15 | 28 | 50 | Die | ||
| QPA2237 | 0.3 | 2.5 | > 40 | > 18.5 | > 48 | 32 | 360 | QFN | ||
| QPA2308 | 5 | 6 | 48 | 22 | 47 | 28 | 1,200 | |||
| QPA2308D | 5 | 6 | 47.8 | 21 | 43 | 28 | ||||
| QPA2309 | 5 | 6 | 50 | |||||||
| QPA2310 | 5 | 6 | 47 | |||||||
| QPA2513 | 3.1 | 3.5 | 51 | 30.4 | 62 | 50 | 228 | SMD | ||
| QPA2576N | 2.5 | 6 | 46 | 29 | 36 | 30 | 1,550 | 10-lead FL style | ||
| QPA2598 | 6 | 12 | 34 | 23 | 30 | 22 | 55 | Overmold QFN | ||
| QPA2611 | 8 | 12 | 38 | 26 | 42 | 24 | 105 | OVM QFN | ||
| QPA2612 | 8 | 12 | 41 | 23 | 40 | 24 | 250 | OVM QFN | ||
| QPA2966D | 2 | 20 | 44 | |||||||
| QPA3055D | 2.9 | 3.6 | 49.5 | 59 | 28 | 300 | Die | |||
| QPA3055P | 2.9 | 3.5 | 50 | 30 | 53 | 30 | 300, 1,500 | 10 lead copper base | ||
| QPA3069 | 2.7 | 3.5 | 50 | 25 | 53 | 30 | 300 | overmold | ||
| QPA3070 | 2.9 | 3.5 | 52 | |||||||
| QPA9901 | 2.11 | 2.2 | 28 | 35.6 | 36.5 | 32 | 5 | 394 | ||
| QPA9903 | 1.805 | 1.88 | 28 | 36 | 32 | 33.8 | 5 | 360 | ||
| QPA9908 | 0.850 | 0.96 | 28 | 36.6 | 32.6 | 36 | 5 | 370 | ||
| QPA9940 | 2.3 | 2.4 | 28 | 36 | 34.5 | 31 | 5 | 406 | 5 x 5 | |
| QPB1500 | 14.85 | 15.75 | 44 | 24 | 35 | 28 | 450 | Cu Base | ||
| QPM1021 | 10 | 12 | 50 | 20 | 32 | 28 | 2,000 | CP | ||
| QPM2239 | 13 | 15.5 | 49 | 25 | 28 | 800 | 10 Lead Copper Base | |||
| TGA2214 | 2 | 18 | > 37 | > 22 | > 20 | 22 | 450 | Die | ||
| TGA2214-CP | 2 | 18 | > 36 | > 22 | > 15 | 22 | 600 | Copper Pillar | ||
| TGA2216 | 0.1 | 3 | > 41 | 22 | > 40 | 48 | 360 | Die | ||
| TGA2216-SM | 0.1 | 3 | > 41 | 22 | 50 | 40 | 360 | QFN | ||
| TGA2222 | 32 | 38 | 40 | 40 | 16 | 22 | 26 | |||
| TGA2237 | 0.03 | 2.5 | 40 | 19 | > 52 | 30 | 360 | Die | ||
| TGA2237-SM | 0.03 | 2.5 | > 40 | > 19 | > 50 | 32 | 360 | QFN | ||
| TGA2307 | 5.0 | 6.0 | > 47 | > 26 | > 40 | 28 | 1,000 | |||
| TGA2307-SM | 5 | 6 | > 47 | > 26 | > 44.4 | 28 | 500 | QFN | ||
| TGA2576-2-FL | 2.5 | 6 | 46.5 | 46.5 | 29 | 36 | 30 | 1,550 | Flange | |
| TGA2578 | 2 | 6 | 45 | 45 | 27 | 40 | 28 | 400 | Die | |
| TGA2578-CP | 2 | 6 | 45 | 26 | 30 | 28 | 400 | Cu Base | ||
| TGA2583 | 2.7 | 3.7 | 40.5 | 33 | 54 | 25 | 175 | Die | ||
| TGA2583-SM | 2.7 | 3.7 | 40.6 | 33 | > 50 | 25 to 32 | 175 | QFN | ||
| TGA2585 | 2.7 | 3.7 | 42.8 | 33 | 52 | 28 | 225 | Die | ||
| TGA2585-SM | 2.7 | 3.7 | 42.5 | 32 | > 50 | 28 | 225 | QFN | ||
| TGA2590 | 6 | 12 | 45 | > 35 | > 25 | 20 | 2,000 | Die | ||
| TGA2590-CP | 6 | 12 | > 45 | 35 | 30 | 20 | 2,000 | Cu Base | ||
| TGA2701-SM | 5.9 | 8.5 | 35 | 18 | 37 | 6 | 1,000 | QFN | ||
| TGA2753-SM | 5.9 | 7.7 | 40 | 31 | 30 | 47 | 28 | 1,000 | QFN | |
| TGA2813 | 3.1 | 3.6 | 50.7 | 22 | 55 | 30 | 150 | Die | ||
| TGA2813-CP | 3.1 | 3.6 | 50 | 23 | 51 | 30 | 300 | Cu Base | ||
| TGA2813-SM | 3.1 | 3.6 | 50 | > 24 | > 56 | 30 | 300 | QFN | ||
| TGA2814-SM | 3.1 | 3.5 | 49.5 | > 24 | 55 | 30 | 200 | QFN | ||
| TGA2817-SM | 2.9 | 3.5 | > 48 | > 24 | 54 | 28 | 200 | QFN | ||
| TGA2818-SM | 2.8 | 3.7 | > 45.5 | > 18 | > 47 | 28 | 200 | QFN | ||
| TGA2830-SM | 2.7 | 3.5 | > 42.5 | > 30.5 | > 54 | 32 | 225 | QFN | ||
| TGA2963 | 6 | 18 | 43 | > 26 | > 20 | 20 | 2,500 | Die | ||
| TGA2963-CP | 6 | 18 | 43 | 26 | 20 | 20 | 2,500 | Flange | ||
| TGA2975-SM | 2.7 | 3.5 | > 41 | 31 | > 52 | 32 | 175 | QFN | ||
| TGA2976-SM | 0.1 | 3 | > 40 | > 20 | 48 | 40 to 50 | 360 | QFN | ||
| TGA4548 | 17 | 20 | 40 | 27 | 30 | 28 | 300 | |||
| TGA4548-SM | 17 | 20 | 40 | 27 | 25 | 28 | 300 | |||
| TGA4549-SM | 21.2 | 23.6 | 40 | 25 | 20 | 300 |
责任编辑:tzh
