DATEL采样A/D转换器是将模拟信号转换成数字信号的电路。A/D转换器的功能是将具有连续时间和幅值的模拟信号转换为离散时间和幅度的数字信号。因此,A/D转换器通常经历采样、保持、量化和编码四个过程。
DATEL采样A/D转换器的特点
分辨率从12位到18位,采样率高达12.8MSPS。
高度商业和军事可靠性
同时完成功能、时域和频域测试
它是医学或生命科学成像、分析仪器、军事脉冲和扩频应用的理想选择。
表面安装版可用
MIL-STD-883型
深圳市立维创展科技有限公司,优势提供DATEL产品渠道,欢迎咨询。
详情了解DATEL请点击:http://www.ldteq.com/public/brand/66.html
或联系我们的销售工程师:0755- 83642657 QQ: 2295048674
Part Number |
Resolution |
Sampling Rate |
Power Consumption |
Package Type |
Signal to Noise Ratio |
Operating Temp. Range (min) |
Operating Temp. Range (max) |
RoHS |
| 5962-9319801HXA |
14 Bit |
5 MHz |
2.95 W |
TDIP |
76 dB |
-55 ºC |
+125 ºC |
No |
| 5962-9319801HXC |
14 Bit |
5 MHz |
2.95 W |
TDIP |
76 dB |
-55 ºC |
+125 ºC |
No |
| 5962-9319803HXC |
14 Bit |
5 MHz |
2.95 W |
TDIP |
76 dB |
-55 ºC |
+125 ºC |
No |
| 5962-9475701HXA |
14 Bit |
1 MHz |
1.9 W |
DDIP |
76 dB |
-55 ºC |
+125 ºC |
No |
| 5962-9475701HXC |
14 Bit |
1 MHz |
1.9 W |
DDIP |
76 dB |
-55 ºC |
+125 ºC |
No |
| ADS-1011LC |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
0 ºC |
+70 ºC |
No |
| ADS-1011LC-C |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
0 ºC |
+70 ºC |
Yes |
| ADS-1011LE |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
-40 ºC |
+100 ºC |
No |
| ADS-1011LE-C |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
-40 ºC |
+100 ºC |
Yes |
| ADS-1011LM |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
-55 ºC |
+125 ºC |
No |
| ADS-1011LM-C |
10 Bit |
0.4 MHz |
20 W |
LCC-24pins |
60 dB |
-55 ºC |
+125 ºC |
Yes |
| ADS-112/883 |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
No |
| ADS-112-C/883 |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
Yes |
| ADS-112MC |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
0 ºC |
+70 ºC |
No |
| ADS-112MC-C |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
0 ºC |
+70 ºC |
Yes |
| ADS-112ME |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-40 ºC |
+100 ºC |
No |
| ADS-112ME-C |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-40 ºC |
+100 ºC |
Yes |
| ADS-112MM |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
No |
| ADS-112MM-C |
12 Bit |
1 MHz |
1.3 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
Yes |
| ADS-117/883 |
12 Bit |
2 MHz |
1.6 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
No |
| ADS-117-C/883 |
12 Bit |
2 MHz |
1.6 W |
DDIP |
72 dB |
-55 ºC |
+125 ºC |
Yes |
| ADS-117G/883 |
12 Bit |
2 MHz |
1.6 W |
SMT |
72 dB |
-55 ºC |
+125 ºC |
No |
| ADS-117GC |
12 Bit |
2 MHz |
1.6 W |
SMT |
72 dB |
0 ºC |
+70 ºC |
No |
| ADS-117G-C/883 |
12 Bit |
2 MHz |
1.6 W |
SMT |
72 dB |
-55 ºC |
+125 ºC |
Yes |
| ADS-117GC-C |
12 Bit |
2 MHz |
1.6 W |
SMT |
72 dB |
0 ºC |
+70 ºC |
Yes |
责任编辑:haq
