MACOM的光电产品还包含适用于配电线路和服务器10g、40g和100g光纤信号接收器的各种跨阻放大器(TIA)。MACOM的产品组合包含适用于远程相关接收器的线性TIA和适用于基于NRZ的短程接收器的有限TIA。MACOM组件具备市场领先的增益值、噪声性能和功能损耗。MACOM以裸晶圆形式供应,并且能够与光学元件中的光电探测器集成化。
深圳立维创展科技是MACOM的代理商,产品提供MACOM可变增益放大器,功率放大器,低噪声放大器,线性放大器,混合放大器, FTTx放大器,分频放大器,放大器增益模块,有源分离器,功分压器,倍频器,混合混频器,混频器,上变频器,数字衰减器,数字移相器,功率测试仪。压控衰减器等半导体,进口,质量保证,欢迎咨询。
详情了解MACOM产品请点击:http://www.leadwaytk.com/public/brand/5.html
或联系我们的销售工程师: 0755-83050846 QQ :3312069749
| Part Number | Max Data Rate (Gbps) | Differential Transimpedance Gain (kOhms) | Small Signal Bandwidth (GHz) | Input Overload Current (mA) | Input Referred Noise(nA) | Optical sensitivity with PIN (dBm) | Optical Sensitivity with APD (dBm) |
| MATA-02239 | 10.3 | 6 | 9 | 1.6 | -32 | ||
| MATA-07825 | 12 | 6 | 9 | 2 | 0.9 | -17 | |
| MATA-02238 | 10.3 | 6 | 9 | 1.6 | 1000 | -31 | |
| MATA-03003 | 28 | 3.8 | 21 | 4 | 1.4 | -18 | |
| MATA-03013 | 28 | 3.8 | 21 | 4 | 1400 | -18 | |
| M03102 | 28 | 2.9 | 22 | 2.8 | 1.4 | -17 | |
| M02006 | 0.2 | 260 | 0.1 | 2.2 | 8 | -39 | |
| M02007 | 0.2 | 62 | 0.14 | 2.8 | 8 | -39 | |
| M02015 | 2.5 | 9 | 1.4 | 4 | 290 | -26 | |
| M02016 | 1.3 | 24 | 1 | 4 | 130 | -29 | |
| M02020 | 4.3 | 3.6 | 3.4 | 4 | 550 | -23 | -29 |
| M02025 | 3.2 | 20 | 1.45 | 4 | 120 | -30 | |
| M02035 | 2.5 | 3.6 | 1.7 | 1.5 | 250 | -33 | |
| M02036 | 1.3 | 3.8 | 0.8 | 2.5 | 170 | -35 | |
| M02038 | 1.2 | 8.5 | 0.85 | 4 | 350 | -34 | |
| M03002 | 28 | 2.9 | 22 | 3.5 | |||
| MATA-02135 | 11.3 | 3.4 | 8.2 | 3 | 850 | -21 | -27 |
| MATA-03006 | 28 | 3.8 | 21 | 4 | 1.4 | ||
| MATA-03106 | 28 | 3.8 | 21 | 4 | 1400 |
责任编辑:haq
