1、跨设备启动FA、跨设备迁移、回迁
(1)权限
ohos.permission.DISTRIBUTED_DEVICE_STATE_CHANGE:用于允许监听分布式组网内的设备状态变化。
ohos.permission.GET_DISTRIBUTED_DEVICE_INFO:用于允许获取分布式组网内的设备列表和设备信息。
ohos.permission.GET_BUNDLE_INFO:用于查询其他应用的信息。
ohos.permission.DISTRIBUTED_DATASYNC:用于允许不同设备间的数据交换。
"reqPermissions": [
{"name": "ohos.permission.DISTRIBUTED_DATASYNC"},
{"name": "ohos.permission.DISTRIBUTED_DEVICE_STATE_CHANGE"},
{"name": "ohos.permission.GET_DISTRIBUTED_DEVICE_INFO" },
{"name": "ohos.permission.GET_BUNDLE_INFO"}
//主动申明,要多设备协同,让用户选择允许还是禁止
requestPermissionsFromUser(new String[]{"ohos.permission.DISTRIBUTED_DATASYNC"}, 0);
(2)界面:ability_main.xml
另外我们需要的Page Abiltiy:MigrationAbility、RemoveAbility MainAbilitySlice:
public class MainAbilitySlice extends AbilitySlice {
private Button mainStartFABtn,mainMigrationBtn;
@Override
public void onStart(Intent intent) {
super.onStart(intent);
super.setUIContent(ResourceTable.Layout_ability_main);
mainStartFABtn = (Button)findComponentById(ResourceTable.Id_main_start_fa_btn);
mainMigrationBtn = (Button)findComponentById(ResourceTable.Id_main_migration_btn);
mainStartFABtn.setClickedListener(mClickListener);
mainMigrationBtn.setClickedListener(mClickListener);
private Component.ClickedListener mClickListener = new Component.ClickedListener() {
@Override
public void onClick(Component component) {
int compoentId = component.getId();
switch (compoentId){
case ResourceTable.Id_main_start_fa_btn:
//点击后跨设备打开Fa
//第一种写法
Intent intent = new Intent();
Operation op = new Intent.OperationBuilder()
.withDeviceId(Common.getOnLineDeviceId())
.withBundleName("com.ybzy.demo")
.withAbilityName("com.ybzy.demo.RemoveAbility")
.withFlags(Intent.FLAG_ABILITYSLICE_MULTI_DEVICE)
.build();
intent.setOperation(op);
intent.setParam("msg","我夸设备把你这个FA拉起来了!");
startAbility(intent);
//第二钟写法
intent.setElement(new ElementName(Common.getOnLineDeviceId()
,"com.ybzy.demo","com.ybzy.demo.RemoveAbility"));
intent.setFlags(Intent.FLAG_ABILITYSLICE_MULTI_DEVICE);
break;
case ResourceTable.Id_main_migration_btn:
//点击后进入要迁移的Ability页面
Intent migrationIntent = new Intent();
migrationIntent.setElement(new ElementName("","com.ybzy.demo"
,"com.ybzy.demo.MigrationAbility"));
startAbility(migrationIntent);
break;
default:
break;
@Override
public void onActive() {
super.onActive();
@Override
public void onForeground(Intent intent) {
super.onForeground(intent);
ability_migration.xml
RemoveAbility...把接收到的值显示到页面就行,setText()
(3)工具类
public class Common{
public static String getDeviceId(){
List deviceList = DeviceManager.getDeviceList(DeviceInfo.FLAG_GET_ONLINE_DEVICE);
if(deviceList.isEmpty()){
return null;
int deviceNum = deviceList.size();
List deviceIds = new ArrayList<>(deviceNum);
List deviceNames = new ArrayList<>(deviceNum);
deviceList.forEach((device)->{
deviceIds.add(device.getDeviceId());
deviceNames.add(device.getDeviceName());
//我们这里的实验环境,就两部手机,组件还没讲
//我就直接使用deviceIds的第一个元素,做为启动远程设备的目标id
String devcieIdStr = deviceIds.get(0);
return devcieIdStr;
public static void myShowTip(Context context,String msg){
//提示框的核心组件文本
Text text = new Text(context);
text.setWidth(MATCH_CONTENT);
text.setHeight(MATCH_CONTENT);
text.setTextSize(16, Text.TextSizeType.FP);
text.setText(msg);
text.setPadding(30,20,30,20);
text.setMultipleLine(true);
text.setMarginLeft(30);
text.setMarginRight(30);
text.setTextColor(Color.WHITE);
text.setTextAlignment(TextAlignment.CENTER);
//给上面的文本设置一个背景样式
ShapeElement style = new ShapeElement();
style.setShape(ShapeElement.RECTANGLE);
style.setRgbColor(new RgbColor(77,77,77));
style.setCornerRadius(15);
text.setBackground(style);
//构建存放上面的text的布局
DirectionalLayout mainLayout = new DirectionalLayout(context);
mainLayout.setWidth(MATCH_PARENT);
mainLayout.setHeight(MATCH_CONTENT);
mainLayout.setAlignment(LayoutAlignment.CENTER);
mainLayout.addComponent(text);
//最后要让上面的组件绑定dialog
ToastDialog toastDialog = new ToastDialog(context);
toastDialog.setSize(MATCH_PARENT,MATCH_CONTENT);
toastDialog.setDuration(1500);
toastDialog.setAutoClosable(true);
toastDialog.setTransparent(true);
toastDialog.setAlignment(LayoutAlignment.CENTER);
toastDialog.setComponent((Component) mainLayout);
toastDialog.show();
(4)实现功能 MigrationAbilitySlice:
public class MigrationAbilitySlice extends AbilitySlice implements IAbilityContinuation {
TextField migrationTextField;
Button migrationMigrationBtn,migrationMigrationBackBtn;
String msg = "";
@Override
super.setUIContent(ResourceTable.Layout_ability_migration);
migrationTextField = (TextField)findComponentById(ResourceTable.Id_migration_textfield);
migrationTextField.setText(msg);
migrationMigrationBtn = (Button)findComponentById(ResourceTable.Id_migration_migration_btn);
migrationMigrationBtn.setClickedListener(component -> {
//1、要进行迁移的Ability实现接口 IAbilityContinuation,实现的方法返回值改成true
//2、要进行迁移的Ability下面关联的所有AbilitySlice都要实现接口 IAbilityContinuation,
// 实现的方法上处理数据
//3、进行迁移
String deviceId = Common.getOnLineDeviceId();
if(deviceId != null){
// continueAbility(deviceId);
continueAbilityReversibly(deviceId);
migrationMigrationBackBtn = (Button) findComponentById(ResourceTable
.Id_migration_migration_back_btn);
migrationMigrationBackBtn.setClickedListener(component -> {
reverseContinueAbility();
@Override
super.onActive();
@Override
@Override
public boolean onStartContinuation() {
return true;
@Override
public boolean onSaveData(IntentParams intentParams) {
intentParams.setParam("msg",migrationTextField.getText());
return true;
@Override
public boolean onRestoreData(IntentParams intentParams) {
msg = intentParams.getParam("msg").toString();
// getUITaskDispatcher().asyncDispatch(() -> {
// migrationTextField.setText(intentParams.getParam("msg").toString());
return true;
@Override
public void onCompleteContinuation(int i) {
2、跨设备连接Service
启动远程设备Service的代码示例如下: 添加按钮:
新建RemoteServiceAbility:
public class RemoteServiceAbility extends Ability {
private static final HiLogLabel LABEL_LOG = new HiLogLabel(3, 0xD001100, "Demo");
private Source sVideoSource;
private Player sPlayer;
@Override
HiLog.error(LABEL_LOG, "RmoteServiceAbility::onStart");
Common.myShowTip(this,"remote onstart");
sPlayer = new Player(RemoteServiceAbility.this);
new PlayerThread().start();
class PlayerThread extends Thread {
@Override
public void run() {
try {
File mp3FilePath = getExternalFilesDir(Environment.DIRECTORY_MUSIC);
if (!mp3FilePath.exists()) {
mp3FilePath.mkdirs();
File mp3File = new File(mp3FilePath.getAbsolutePath() + "/" + "bj.mp3");
Resource res = getResourceManager()
.getRawFileEntry("resources/rawfile/bj.mp3").openRawFile();
byte[] buf = new byte[4096];
int count = 0;
FileOutputStream fos = new FileOutputStream(mp3File);
while ((count = res.read(buf)) != -1) {
fos.write(buf, 0, count);
FileDescriptor fileDescriptor = new FileInputStream(mp3File).getFD();
sVideoSource = new Source(fileDescriptor);
sPlayer.setSource(sVideoSource);
sPlayer.prepare();
sPlayer.setVolume(0.3f);
sPlayer.enableSingleLooping(true);
sPlayer.play();
} catch (IOException e) {
e.printStackTrace();
@Override
public void onStop() {
super.onStop();
Common.myShowTip(RemoteServiceAbility.this,"remote onStop");
sPlayer.stop();
@Override
public IRemoteObject onConnect(Intent intent) {
return null;
@Override
public void onDisconnect(Intent intent) {
启动:
case ResourceTable.Id_main_start_remoteService_btn:
Common.myShowTip(MainAbilitySlice.this,deviceId);
Intent startRemoteServiceIntent = new Intent();
startRemoteServiceIntent.setElement(new ElementName(
deviceId,
"com.ybzy.demo",
"com.ybzy.demo.RemoteServiceAbility"
startRemoteServiceIntent.setFlags(Intent.FLAG_ABILITYSLICE_MULTI_DEVICE);
startAbility(startRemoteServiceIntent);
break;
关闭远程设备Service:
case ResourceTable.Id_main_stop_remoteService_btn:
Intent stopRemoteServiceIntent = new Intent();
stopRemoteServiceIntent.setElement(new ElementName(
deviceId,
"com.ybzy.demo",
stopRemoteServiceIntent.setFlags(Intent.FLAG_ABILITYSLICE_MULTI_DEVICE);
stopAbility(stopRemoteServiceIntent);
break;
仅通过启动和停止Service Ability两种方式对Service进行调度无法应对需长期交互的场景, 简单地说,信息就是只能去,回不来! 因此,分布式任务调度平台向开发者提供了跨设备Service连接及断开连接的能力。 链接上了,信息可去可回! 链接是使用connectAbility()方法,需要传入目标Service的Intent与接口IAbilityConnection的实例对象。 接口IAbilityConnection提供了两个方法供开发者实现: (1)onAbilityConnectDone()用来处理连接的回调。 (2)onAbilityDisconnectDone()用来处理断开连接的回调。 我们可以在onAbilityConnectDone()中获取管理链接的代理,进一步为了使用该代理跨设备调度Service, 开发者需要在本地及远端分别实现对外接口一致的代理,这个接口是IRemoteBroker。 添加按钮:
发起连接的本地侧的代理示例如下:
public class MyRemoteProxy implements IRemoteBroker {
//IRemoteBroker:获取远程代理对象的持有者
private static final int ERR_OK = 0;
//COMMAND_PLUS表示有效消息进行通信的约定的标记,MIN_TRANSACTION_ID是这个标记可以用的最小值:1
private static final int COMMAND_PLUS = IRemoteObject.MIN_TRANSACTION_ID;
//IRemoteObject:此接口
// 可用于查询或获取接口描述符、
// 添加或删除死亡通知、
// 将对象状态转储到特定文件以及发送消息。
private final IRemoteObject remote;
public MyRemoteProxy(IRemoteObject remote) {
this.remote = remote;
@Override
public IRemoteObject asObject() {//获取远程代理对象的方法
return remote;
public int plus(int a,int b) throws RemoteException {
//MessageParcel:这个类提供了读写对象、接口标记、文件描述符和大数据的方法。
MessageParcel data = MessageParcel.obtain();
//obtain()创建索引为0的空MessageParcel对象
MessageParcel reply = MessageParcel.obtain();
//MessageOption:定义与sendRequest一起发送消息的选项。
// option不同的取值,决定采用同步或异步方式跨设备调用Service
// 这个例子我们需要同步获取对端Service执行加法运算后的结果,同步模式调用sendRequest接口,即MessageOption.TF_SYNC
// 对应的是异步:TF_ASYNC
MessageOption option = new MessageOption(MessageOption.TF_SYNC);
data.writeInt(a);
data.writeInt(b);
try {
remote.sendRequest(COMMAND_PLUS, data, reply, option);
//第1个参数:约定通信双方确定的消息标记。
//第2个参数:发送到对等端侧的数据包裹MessageParcel对象。
//第3个参数:对等端侧返回的数据包裹MessageParcel对象。
//第4个参数:设置发送消息,用同步还是异步模式。
int ec = reply.readInt(); //返回通信成不成功,约定的标记ERR_OK
if (ec != ERR_OK) {
throw new RemoteException();
int result = reply.readInt();
return result;
} catch (RemoteException e) {
} finally {
data.reclaim(); //reclaim()清除不再使用的MessageParcel对象。
reply.reclaim();
等待连接的远端侧的代理示例如下:
public class MyRemote extends RemoteObject implements IRemoteBroker{
private static final int ERROR = -1;
public MyRemote() {
super("MyService_Remote");
@Override
return this;
@Override
public boolean onRemoteRequest(int code, MessageParcel data, MessageParcel reply, MessageOption option) {
if (code != COMMAND_PLUS) {
reply.writeInt(ERROR);
return false;
int value1 = data.readInt();
int value2 = data.readInt();
int sum = value1 + value2;
reply.writeInt(ERR_OK);
reply.writeInt(sum);
return true;
等待连接侧还需要作如下修改:
// 绑定前面定义的代理,实例化出发起链接侧需要的代理
private MyRemote remote = new MyRemote();
@Override
//链接成功的时候,给发起链接侧返回去
return remote.asObject();
完成上述步骤后,可以通过点击事件实现连接、利用连接关系控制PA以及断开连接等行为,代码示例如下:
private MyRemoteProxy mProxy = null;
// 创建连接回调实例
private IAbilityConnection conn = new IAbilityConnection() {
// 连接到Service的回调
@Override
public void onAbilityConnectDone(ElementName elementName, IRemoteObject iRemoteObject, int resultCode) {
// 在这里开发者可以拿到服务端传过来IRemoteObject对象,从中解析出服务端传过来的信息
mProxy = new MyRemoteProxy(iRemoteObject);
UIUtils.showTip(MainAbilitySlice.this,"拿到remoteObject:" + mProxy);
// 意外断开连接才会回调
@Override
public void onAbilityDisconnectDone(ElementName elementName, int resultCode) {
// 连接远程
case ResourceTable.Id_main_connect_remoteService_btn:
//1、实现连接的本地侧的代理
//2、实现等待连接的远端侧的代理
//3、修改等待连接侧的Service
//4、在本地(发起链接侧)获取远端(被链接侧)返回过来的链接代理,创建链接后的回调函数
//5、实现链接,通过代理对象使用Service的服务
if (deviceId != null) {
Intent connectServiceIntent = new Intent();
connectServiceIntent.setElement(new ElementName(
deviceId,
"com.ybzy.demo",
connectServiceIntent.setFlags(Intent.FLAG_ABILITYSLICE_MULTI_DEVICE);
connectAbility(connectServiceIntent, iAbilityConnection);
break;
// 链接后使用
case ResourceTable.Id_main_use_remoteService_btn:
if (mProxy != null) {
int ret = -1;
try {
ret = mProxy.plus(10, 20);
Common.myShowTip(MainAbilitySlice.this, "获取的结果:" + ret);
break;
// 用完断开
case ResourceTable.Id_main_disconnect_remoteService_btn:
disconnectAbility(iAbilityConnection);
break;
编辑:hfy
