本文档的主要内容详细介绍的是开关电源中的技术名词解释免费下载。
开关电源A Auxiliary supply(辅助电源) B B-H curve(磁化曲线) Bipolar transistor(双极型晶体管) Avalanche(雪崩) base drive(基极驱动) forward bias safe operating area (FBSOA,正向偏置安全工作区) reverse bias safe operating area(RBSOA,反向偏置安全工作区) safe operating area(安全工作区) secondary breakdown( 二次击穿) storage time(储存时间) veco vecs Boost converter(Boost 变换器) Compensation(补偿) Control equation(控制等式) Buck converter (Buck 变换器) Compensation(补偿) Control equation(控制等式) Buck-Boost converter(Buck-Boost 变换器) C Capacitor(电容) Aluminum(铝) Ceramic(陶瓷的) EMI filter(EMI 滤波器) Equivalent circuit(等效电路) Equivalent series inductance(等效串联电感) Failure mode(失效模式) Film(薄膜) Flammability(可燃性) Metallized paper(镀金属纸) Metallized film(镀金属膜) Multilayer ceramic(多层陶瓷的) Niobium(铌) Polymer electrolytic(聚合物电解) Polymer tantalum(聚合物钽) Reservoir(储能的) Ripple current(纹波电流) Self-heating(自加热) Tantalum(钽) Temperature coefficient(温度系数) Capacitor definition(电容定义) Charge pump(电荷泵) Clamp circuit(钳位电路) Common mode interference(共模干扰) Compensation(补偿) Laboratory method(实验室方法) Continuous operation(连续工作) Current limit(限流) Current mode PWM controller(电流模式 PWM 控制器) Current sense(电流检测) Current transformer(电流互感器) D DC-DC converter(直流-直流变换器) Dead time(死区时间) Differential mode interference(差模干扰) Diode(二极管) Forward recovery(正向恢复) Gallium arsenide(砷化镓,气体) Junction(PN 结) PIN(引脚) Reverse recovery(反向恢复) Schottky(肖特基) Silicon carbide(sic,碳化硅) Soft recovery(软恢复) Standard recovery(标准恢复) Ultra-fast(超快速) Discontinuous operation(断续工作) Dissipation factor(损耗因数) E Eddy current(涡流) Electromagnetic compatibility(EMC,电磁兼容)
全部1条评论
