步骤如下:
1. 创建 tap 设备:
sudo ip tuntap add dev tap0 mode tap
2. enable tap0接口:
sudo ip link set tap0 up
3. 添加路由:
sudo ip route add 192.168.0.10/32 dev tap0
或者用旧的命令:
sudo route add -host 192.168.1.10 tap0
这样,任何目标地址为
192.168.1.10
的包都会被 route到tap0.
4. 使用 ARP proxy:
sysctl net.ipv4.conf.tap0.proxy_arp=1
sysctl net.ipv4.conf.wlp3s0.proxy_arp=1
或者:
echo 1 》 /proc/sys/net/ipv4/conf/tap0/proxy_arp
echo 1 》 /proc/sys/net/ipv4/conf/wlp3s0/proxy_arp
5. Enable IP forwarding
sysctl net.ipv4.ip_forward=1
或者:
echo 1 》 /proc/sys/net/ipv4/ip_forward
6.启动虚拟机:
。/qemu-2.8.0/arm-softmmu/qemu-system-arm -M vexpress-a9 -m 1024 -smp 4 -kernel 。/linux-4.9.13/arch/arm/boot/zImage
-sd rootfs.img -append “root=/dev/mmcblk0 rw rootfs=ext4 rootdelay=3 physmap.enabled=0 console=ttyAMA0 console=tty0”
-dtb 。/linux-4.9.13/arch/arm/boot/dts/vexpress-v2p-ca9.dtb -netdev tap,id=mytest,ifname=tap0,scripts=no,downscript=no
-device virtio-net-device,netdev=mytest -nographic
然后,设置虚拟机IP地址:
ip addr add 192.168.0.10 dev eth0
添加路由:
ip route add default via 192.168.0.101 dev eth0
设置和主机一样的nameserver:
cat 》》 /etc/resolv.conf
nameserver 192.168.0.1
Ctrl-D
#ping www.baidu.com
