应用案例
TI公司的TPS546D24A是高度集成非隔离DC/DC转换器,具有高频工作,输出电流40A,封装为7mmx5mm 40引脚QFN封装.两个,三个和四个TPS546D24A可以互连,单输出可提供高达160A输出.TPS546D24A采用专有的固定频率电流模式控制,具有输入正馈和可选择的内部补偿元件,以最小化尺寸和大范围输出电容下稳定性.PMBus接口具有1MHz时钟,支持方便标准化的数字接口,用于转换器配置和监视主要参数包括输出电压,输出电流和内部芯片温度.器件分立的轨电压支持2,95V-16V PVIN;2.9V-18V AVIN,集成了4.5-mΩ/0.9-mΩ MOSFET,2×, 3x, 4×可堆栈共享电流高达160A,每个输出支持单地址.12个可选开关频率,从225 kHz 到1.5 MHz.主要用在数据中心交换,机架式服务器,有源天线系统,遥控无线电和基带单元,自动测试,CT,PET和MRI以及ASIC,SoC,FPGA,DSP核和I/O电压.中电网为您整理如下互联网详细资料本文介绍了TPS546D24A主要特性,功能框图,平均电流模式控制框图,单个和两个器件应用电路,以及两相降压转换器评估板TPS546D24AEVM-2PH主要特性和指标,电路图,材料清单,PCB设计图.以及四相160A同步降压转换器参考设计PMP21814框图,电路图,材料清单和PCB设计图.
The TPS546D24A is a highly integrated, non-isolatedDC/DC converter capable of high frequency operationand 40-A current output from a 7-mm × 5-mmpackage. Two, three, and four TPS546D24A devicescan be interconnected to provide up to 160 A on asingle output. The device has an option to overdrivethe internal 5-V LDO with an external 5-V supply viathe VDD5 pin to improve efficiency and reduce powerdissipation of the converter.
The TPS546D24A uses a proprietary fixed-frequencycurrent-mode control with input feedforward andselectable internal compensation components forminimal size and stability over a wide range of outputcapacitances.
The PMBus interface with 1-MHz clock support givesa convenient, standardized digital interface forconverter configuration as well as monitoring of keyparameters including output voltage, output current,and internal die temperature. Response to faultconditions can be set to restart, latch off, or ignore,depending on system requirements. Back-channelcommunication between stacked devices enables allTPS546D24A converters powering a single output railto share a single address to simplify systemsoftware/firmware design. Key parameters includingoutput voltage, switching frequency, soft-start time,and overcurrent fault limits can also be configuredthrough BOM selection without PMBuscommunication to support program free power-up.
TPS546D24A主要特性:
• Split rail support: 2.95-V to 16-V PVIN;2.95-V to 18-V AVIN (4-VIN VDD5 for switching)
• Integrated 4.5-mΩ/0.9-mΩ MOSFETs
• Average current mode control with selectableinternal compensation
• 2×, 3x, 4× stackable with current sharing up to160 A, supporting a single address per output
• Selectable 0.6-V to 5.5-V output via pin strap or0.25-V to 6.0-V using PMBus VOUT_COMMAND
• Extensive PMBus command set with telemetry forVOUT, IOUT and internal die temperature
• Differential remote sensing with internal FB dividerfor < 1% VOUT error –40°C to +150°C TJ
• AVS and margining capabilities through PMBus
• MSEL pins pin programming PMBus defaults
• 12 Selectable switching frequencies from 225 kHzto 1.5 MHz (8 pin-strap options)
• Frequency sync in/sync out
• Supports prebiased output
• Supports strongly coupled inductor
• 7 mm × 5 mm × 1.5 mm, 40-pin QFN,Pitch = 0.5 mm
• Create a Custom Design Using the TPS546D24AWith WEBENCH® Power Designer
TPS546D24A应用:
• Data center switches, rack servers
• Active antenna system, remote radio andbaseband unit
• Automated test equipment, CT, PET, and MRI
• ASIC, SoC, FPGA, DSP core, and I/O voltage
