线路接口
RJ45 120欧姆;T1 DSX-1/CSU-1 Line-buildouts
帧处理
独立的2个帧处理器,分别处理收和发.支持的帧格式:CRC4/non-CRC4/ESF/D4T1/E1
自动产生DS1空闲码.支持ANSI T1.403-1998
能产生和检测RAI-CI/AIS-CI/RAI.
RCL, RLOS, RRA和RAIS中断告警.
电信标准
ANSI: T1.403-1995, T1.231–1993, T1.408
AT&T: TR54016, TR62411
ITU: G.703, G.704, G.706, G.736, G.775, G.823, G.932, I.431, O.151, Q.161
ITU-T: Recommendation I.432–03/93 B-ISDN User-Network Interface—Physical Layer
Specification
ETSI: ETS 300 011, ETS 300 166, ETS 300 233, CTR12, CTR4
Japanese: JTG.703, JTI.431, JJ-20.11 (CMI Coding Only)
环境参数
温度范围:0-50摄氏度
指示灯
每个接口1个三色指示灯,共4个指示灯
