Firefly-RK3128 开发板上有 4 路 PWM 输出,分别为 PWM0 ~ PWM3,其中:
本章主要描述如何配置 PWM。 Firefly-RK3128 的 PWM 驱动为:
kernel/drivers/pwm/pwm-rockchip.c 配置 PWM 主要有以下三大步骤:配置 PWM DTS 节点、配置 PWM 内核驱动、控制 PWM 设备。
配置 PWM DTS节点
在 kernel/arch/arm/boot/dts/rk312x.dtsi 定义了以下 PWM 节点,如下所示:
pwm0: pwm@20050000 {compatible = "rockchip,rk-pwm";reg = <0x20050000 0x10>;#pwm-cells = <2>;pinctrl-names = "default";pinctrl-0 = <&pwm0_pin>;clocks = <&clk_gates7 10>;clock-names = "pclk_pwm";status = "disabled";}; pwm1: pwm@20050010 {compatible = "rockchip,rk-pwm";reg = <0x20050010 0x10>;#pwm-cells = <2>;pinctrl-names = "default";pinctrl-0 = <&pwm1_pin>;clocks = <&clk_gates7 10>;clock-names = "pclk_pwm";status = "disabled";}; pwm2: pwm@20050020 {compatible = "rockchip,rk-pwm";reg = <0x20050020 0x10>;#pwm-cells = <2>;pinctrl-names = "default";pinctrl-0 = <&pwm2_pin>;clocks = <&clk_gates7 10>;clock-names = "pclk_pwm";status = "disabled";}; pwm3: pwm@20050030 {compatible = "rockchip,rk-pwm";reg = <0x20050030 0x10>;#pwm-cells = <2>;pinctrl-names = "default";pinctrl-0 = <&pwm3_pin>;clocks = <&clk_gates7 10>;clock-names = "pclk_pwm";status = "disabled";}; remotectl: pwm@20050030 {compatible = "rockchip,remotectl-pwm";reg = <0x20050030 0x10>;#pwm-cells = <2>;pinctrl-names = "default";pinctrl-0 = <&pwm3_pin>;clocks = <&clk_gates7 10>;clock-names = "pclk_pwm";remote_pwm_id = <3>;interrupts = ;status = "okay";}; 要使用 pwm0, 只需在 kernel/arch/arm/boot/dts/rk3128-fireprime.dts 加入:
&pwm0 { status = "okay"; }; PWM 驱动位于文件 kernel/drivers/pwm/pwm-rockchip.c。
用户可在其它驱动文件中使用以上步骤生成的 PWM 节点。具体方法如下:
#include 该头文件主要包含 PWM 的函数接口。
使用
struct pwm_device *pwm_request(int pwm_id, const char *label); 函数申请 PWM。例如:
struct pwm_device * pwm0 = NULL;pwm0 = pwm_request(0, “backlight-pwm”); 参数 pwm_id 表示要申请 PWM 的通道,label 为该 PWM 所取的标签。
使用
int pwm_config(struct pwm_device *pwm, int duty_ns, int period_ns); 配置 PWM 的占空比,例如:
pwm_config(pwm0, 500000, 1000000); 参数 pwm 为前一步骤申请的 pwm_device。duty_ns 为占空比激活的时长,单位为 ns。period_ns 为 PWM 周期,单位为 ns。
函数
int pwm_enable(struct pwm_device *pwm); 用于使能 PWM,例如:
pwm_enable(pwm0); 参数 pwm 为要使能的 pwm_device。
控制 PWM 输出主要使用以下接口函数:
struct pwm_device *pwm_request(int pwm_id, const char *label); void pwm_free(struct pwm_device *pwm); int pwm_config(struct pwm_device *pwm, int duty_ns, int period_ns); int pwm_enable(struct pwm_device *pwm); void pwm_disable(struct pwm_device *pwm); 全部0条评论
