Up to 1.25Gb/s bi-directional data links
Hot-pluggable SFP footprint
Fully metallic enclosure for low EMI
RoHS compliant and Lead Free
Low power dissipation (1.05 W typical)
Compact RJ-45 connector assembly
Access to physical layer IC via 2-wire serial bus
10/100/1000 BASE-T operation in host systems with SGMII interface
Extended case temperature range: -40°C to 85°C
1.25 Gigabit Ethernet over Cat 5 cable
