Intel® Atom N270处理器, 10*Intel千兆网口, 1*Bypass
| General | |
| CPU | Intel® Atom™ N270, 1.6 GHz, TDP 2.5W |
| Chipset | Intel® 945GSE + ICH7M |
| Memory | 2 GB DDR2 533/400 SDRAM, 1*SO-DIMM |
| Storage | 2*SATA 2.0, 1*CF |
| Expansion Interface | 2*Mini-PCI, 1*PCI- PCIe Connecting Finger |
| BIOS | Award BIOS |
| System | Windows, Linux |
| I/O Interface | |
| Serial Port | 2*COM |
| USB | 4*USB |
| Ethernet | 2*Intel® PCIe Gigabit LAN, 8*Switch LAN |
| Audio | Null |
| PS/2 | 1*PS/2 header |
| Parallel Port | Null |
| GPIO | 12 programmable GPIO |
| Feature Interface | Null |
| Display | |
| Display Interface | 1*VGA: resolution up to 2048*1536@60Hz |
| Multiple Display | Null |
| Mechanical & Environment | |
| Dimension | 234*185mm |
| Power Input | DC 12V or ATX |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
