Intel® Kaby Lake 7th Gen Core i3/i5/i7 CPU (LGA1151) with H270, Supports OPS-C+, 4K UHD, 2*Mini-PCIe, DC 19V Input
| General | |
| CPU | Intel® Kaby Lake Pentium®/ Celeron®/ 7th Generation CoreTM i3/i5/i7 CPU, LGA1151 |
| Chipset | Intel® H270 Chipset, TDP 6W |
| Memory | Up to 8 GB DDR3L 1600/1333 MHz, 1*SO-DIMM |
| Storage | 1*SATA 3.0 (22Pin), 1*mSATA |
| Expansion Interface |
2*Mini-PCIe (1*mSATA Supported,1*Wifi/3G/4G Supported) 1*OPC-C+ Port |
| BIOS | AMI UEFI BIOS |
| System | Windows 10 x64, Linux |
| I/O Interface | |
| Serial Port | 1*RS232 |
| USB | 2*USB 3.0, 4*USB 2.0 (6*on rear I/O) |
| Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
| Audio | Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-outPorts |
| PS/2 | Null |
| Parallel Port | Null |
| GPIO | Null |
| Feature Interface | Null |
| Display | |
| Display Interface |
1*VGA: max resolution up to 1920*1200 1*HDMI: max resolutionup to 4096*2160 |
| Multiple Display | Dual |
| Mechanical & Environment | |
| Dimension | 170*190mm |
| Power Input | DC 19V |
| Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
| Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
